Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Retreads?
Old Jan 16, 2011 | 09:52 PM
1976 Ford F250's Avatar
1976 Ford F250
Retreads?
I have a '76 f250 highboy that is my mud truck. it needs new tires. Are retreads a good idea?
Old Jan 16, 2011 | 10:14 PM
80broncoman's Avatar
80broncoman
Sure are. that CAN save you some money. unless you find a real god deal on new ones.
I think for the most part they have become less popular due to cheap imported tires.
Old Jan 17, 2011 | 04:26 PM
Supercab's Avatar
Supercab
Are you running 16.5 wheels? are you running a tire that IS available in a recap?
If all you are really doing with the truck is running in the mud then the caps are perfectly fine!
Old Jan 17, 2011 | 09:07 PM
cj06's Avatar
cj06
big rigs run retreads !
Old Jan 18, 2011 | 09:48 AM
dmanlyr's Avatar
dmanlyr
Just keep the retreads off of the steer axle(s) and you will be fine, OR limit your use to NON hyway speeds.
David
Old Jan 18, 2011 | 10:40 AM
Rice Equipment's Avatar
Rice Equipment
If you want caps for a mud truck, you may find that cold caps, which are denser rubber and last longer, are not available in an aggressive tread design. Hot caps, made from a softer rubber,are more aggressive, but don't last long. I don't recommend caps for extended highway use, as the heat build up will cause them to separate. The damage to your truck will be heart breaking. Local driving or off road no problem, even on the front. You can tell some big rigs use them by the rubber laying along the road.
Old Jan 18, 2011 | 11:19 AM
Beechkid's Avatar
Beechkid
yes but, I would only run them on the rears...just like the big rigs do! In federal regs, on fire apparatus & school buses, they are prohibited from running them on the front!
Old Jan 18, 2011 | 11:22 AM
douglpr42's Avatar
douglpr42
for short slow hauls no problem . ilegal in canada to put a recap on front steer axles . the problem with recaps is heat put them on heat takes them off.
Old Jan 18, 2011 | 11:34 AM
cj06's Avatar
cj06
who sells retreads these days for 16" or 16.5" tires ?
Old Jan 18, 2011 | 11:48 AM
LBF's Avatar
LBF
maybe these guys?
Retread Tires - Buy Retread Tires, Cheap Tires, Off Road Tires, and Retreads Online
Old Jan 23, 2011 | 01:27 PM
1976 Ford F250
to cj06 treadwright.com has retread tires for all rim sizes up to 17" or 18"
Old Jan 24, 2011 | 08:08 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking Recaped Tires
Check with big truck shops in your area , they can put you in contact with local retreaders. There is a retreader in my area that does custom work , he can put tractor tread on 15" and larger tires. A lot of the locals setup there mud trucks with them. This guy is a Bandag dealer and his caps hold up OK. I had 4 on the back of my dump with a rough traction tread , they held up till I cut one down on rock.
Have A Great Day--------- Hotwrench
Old Jan 24, 2011 | 11:12 AM
Fosters's Avatar
Fosters
I run treadwright BFG A/T TA KO retreads on my X and so far so good; only have about 5k miles on them though. Cold weather, steering axle, highway speeds, they do it all without complaining.
I have them on my cherokee too, but different pattern/size. I have yet to take that offroad or put lotsa miles on it though
I wish they had 315/35/17 drag radial retreads for my mustang, them things get expensive every 10k miles...
xc4jokestomper
Jul 23, 2012 08:30 AM
builtforddan
Mar 1, 2011 12:21 PM
nebechanezer
23
Feb 15, 2006 04:54 PM
abroom
Offroad & 4x4
Jan 21, 2005 02:52 AM
bremen242
Offroad & 4x4
Sep 25, 2004 06:39 AM
