Truck wont start!!!
Old Jan 8, 2011 | 03:50 PM
Jnix12's Avatar
Jnix12
Truck wont start!!!
So ive been running an edge evolution cs on my truck on the level 2 (towing) program, and everything has been running great.
Well today i got bored, and decided to explore the custom tuning options. I didnt actually change anything, but when i was done it re programmed the truck to level 2 again. According to the tuner, all went well. So i turned the truck off, and tried to start it, but nothing.
Wont even crank, i have power to everything but the ignition.
The tuner is now locked up and wont even recognize the truck.
I'm at my ranch, 57 miles from home.
Anything i can do??
Old Jan 8, 2011 | 04:02 PM
tecrousore's Avatar
tecrousore
unplug it
Try unplugging the Edge from the ODBII port for a couple of seconds then plug it back in. My edge Evolution has locked up in the past and unplugging it has helped to unstick it. Hope this helps.
Old Jan 8, 2011 | 04:04 PM
Jnix12's Avatar
Jnix12
Ive tried unplugging many times.
I really hope i dont have to tow it all the way back to town to get re flashed by ford.
But im starting to think i have no other options.
Old Jan 8, 2011 | 04:15 PM
dchamberlain's Avatar
dchamberlain
You might be able to call Edge and they might be able to unlock the tuner so it can put the stock file back into the truck. But it's a long shot.
Old Jan 8, 2011 | 04:22 PM
Jnix12's Avatar
Jnix12
Edge employees aren't working on saturdays.
I need to figure out if the computer can still be saved or if i'm ultimately going to have to have the pcm reflashed.
Old Jan 8, 2011 | 04:28 PM
amadas350's Avatar
amadas350
can u not take it off, unhook batteries and cut lights on, then retry with edge off?
Old Jan 8, 2011 | 04:33 PM
dchamberlain
It depends on whether the stock file remains intact in the Edge, and if so, can something be done to make it download it back to the truck. If this can't be done, then you're going to have to have Ford put the truck back to stock.
You might try resetting the PCM, disconnect the batteries, turn on the headlights for a few minutes to drain the capacitors in the PCM's memory, then reconnect everything. This might allow the Edge to reconnect.
Old Jan 8, 2011 | 04:54 PM
Jnix12's Avatar
Jnix12
I just tried that, unfortunately it didnt work.
Looks like i'll be in a ranger until monday.
mjtpolice76
Jul 19, 2017 05:16 PM
waumpuscat
Jun 25, 2016 12:15 AM
eattheonions
May 15, 2015 12:55 AM
F350Scott
Computer Chips & Tuners
May 14, 2009 07:08 PM
mikemonster
Feb 28, 2007 12:36 AM
