Radio not working
Old Jul 17, 2017 | 04:55 PM
mjtpolice76's Avatar
mjtpolice76
Radio not working
The short story is I sent my chip to dp tuner last week while on vacation to have Jody update my programs. The ecu was out of the truck for about a week. I reinstalled everything today. Everything works fine except my radio won't turn on. Clock only comes on when headlights are on. Checked all the fuses all good except #32 which is a 5a. Manual says it's the radio start fuse. Fuse is fine not blown out, new one installed still no power on either side of the fuse. Where should I look now. 2002 super duty
Old Jul 19, 2017 | 07:51 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If I were in your position and have verified fuses good with continuity tester, not just a visual inspection I would get in touch with DP and see if this has been a problem in the past. If so, they will likely have a solution for you already and if not, then you can start digging deeper.
Old Jul 19, 2017 | 07:59 AM
mjtpolice76
Fuse was verified good the bus bars in the fuse box are failing have to get new fuse box
Old Jul 19, 2017 | 04:34 PM
white Buffalo's Avatar
white Buffalo
have you checked the vehicle voltage out? are you getting enough juice from the alternator?
Old Jul 19, 2017 | 04:56 PM
mjtpolice76
14.1-14.2 seems good
Old Jul 19, 2017 | 05:16 PM
white Buffalo
looks good, it was just a thought. When my batteries would get really low my radio gauges would not work
crazyjerry
Electrical Systems/Wiring
Feb 1, 2019 08:56 AM
dtfanning
Escape & Escape Hybrid
Apr 1, 2016 11:24 AM
Topkat69
Dec 31, 2014 10:22 AM
Ultimate4x4
Dec 23, 2012 07:13 PM
yamagobo
Jan 7, 2008 03:50 PM
