HELP LOST PCM Programming
This past weekend I was going to let a friend see how his truck performed using my SuperChips 1705. I put my truck in "stock programming and then we plugged into his truck (mine is a 97 PSD his is a 94 PSD). Everthing was going fine we went through the prompts for programming w/o towing, no speed limit, the programmer saved his programming and began loading the "tuned program". It got to the end and listed and error (22?) and said to contact Superchips This is where it got bad..... we tried to check what program was in his truck but the tuner would not read his truck it just kept posting the error. His truck started so we thought his truck was fine. THEN, we took the tuner back to my 97 and when we plugged it in it went through the normal checks we then selected tuning and the programmer started installing "stock program". After this my truck would not start . I had it towed to the dealer and According to the local Ford dealer I've lost everything in my PCM and it needs to be replaced. Superchips is unable to help unless I send them my tuner and PCM. Dealer wants $835 to replace the PCM. I originally thought the dealer would be able to reload the stock programing but this dealer say they can't and the only fix is to install a new PCM. Does anyone have a suggestion on how I can get my truck back on the road?
Thanks,
MIke
Thanks,
MIke
On my friends programming yes it was returned to stock (we checked it after the programmer copied his program into my PCM) but the first error in the Superchips stored his stock programming which was then loaded into my PCM which is what caused the problem. I feel the Superchip should have detected the mis-match VIN when it was put in my truck so that his program didn't get installed in my PCM (which I will try to resolve with Superchips)
Since my post I visited the dealer and after going thru the Service manager (who doesn't really understand how the PCM is programmed and originally told me that it needed to be replaced because it was dead) I talked to the lead tech that work on the truck and who confirmed what I already knew....the PCM is functional but it needs to be reprogrammed and the old stock program needed to be restored. He then said that "the dealership does not have the ability to completely restore the PCM programming. This is not what I was told by the service manager when I had the truck towed there otherwise I would have had it towed to my home.
I can R&R the PCM that's not a problem, however getting it reprogrammed may be more expensive than replacing it with a used one (need the exact same PCM as they differ year to year, AT or MT, engine, state , emissions) there appears to be several different PCMs for 1997 PSD's. I'll get the complete number off of my PCM once I get the truck home today.
Thanks,
Mike
Thanks,
Mike
Finally found and bought a replacement PCM, now I'll try to work with SuperChips on re-programming my original PCM & Tuner. The 1705 should have (but didn't) perform a Vin check and re-programmed my old PCM...........more to come once SC gets my stuff and tells me what they will do for me.
Mike
Mike
I've never had that kind of difficulty with a superchips. Can the tuner communicate with the old PCM? If so, the dealership just doesn't want to do the work, but you might be able to do it yourself if your willing to buy an interface. Read this page http://www.motorcraftservice.com/vdi...&menuIndex1=38
The EEpod was the cheapest I could find at $500, and a 3 day subscription is $15 so you would still be a few hundred a head.
ReAX,
The problem is that the SC failed to VIN lock and "restored" the stock program from another PCM over my stock PCM programming. As I said in my last post, I got a replacement PCM and the truck is now running stock programming. I'm sending my old original PCM and SC 1705 in to SuperChip. I will post the outcome.
thanks
Mike
thanks
Mike
Spool&Go
01-17-2017 10:49 AM
MTNWOODY
68
06-16-2012 06:24 AM
BROWN DOG KTM
Computer Chips & Tuners
19
12-02-2011 11:37 AM
1705, dealership, ford, lock, pcm, problem, program, programed, programing, programmer, programming, replacing, stored, superchips, vin
