One step closer...
6gals = 24 quarts.. Well at least 19 quarts for the trans/converter/lines/cooler, 3 for the transfer case, then 2 quarts for spare. I'd rather just round up and have extra. Plus most stores should carry cases of 12 quarts.
your gunna love that auto with a shift kit.no more mushy wasted energy going into heat and less clutch ware.
what did you get for a converter?
since you going to be in there.did you consider upgrading to the high volume pump and viton pump seal?
Ford E4OD/4R100 FRONT PUMP , CASTING # F5 , COMPLETE - eBay (item 400152613151 end time Feb-06-11 08:22:13 PST)
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
seal info:
https://www.ford-trucks.com/forums/9...od-tranny.html
don't lose your ***** lol:
https://www.ford-trucks.com/forums/8...our-*****.html
as you can see the instructions are great for the shift kit.but has a really poor quality pic for check ball locations.
that will help if you lose your way.
i wish i had set the spring and filter on there for a complete pic.that was kinda dumb of me.but as you can see,the pic in the instructions show them ok.so between the two,you'll be good.
FORD E4OD TRANSMISSION COMPLETE PUMP ASSEMBLY LATE F5 - eBay (item 180589793941 end time Jan-18-11 07:37:20 PST)
seal info:
Trans is from a '97 stroke and was rebuilt by Ford. So the pump/seal should be the updated ones.
Converter:
Ford E4OD 4R100 4 Studs Heavy Duty Torque Converter - eBay (item 230563199789 end time Jan-12-11 09:14:07 PST)
Was $215 shipped. Came in less then a week.
Monday my buddy comes with his gooseneck trailer and PSD and we'll haul off my truck to his shop and fix it.. HOPEFULLY, i'll be driving it home that night..
