Power Steering Pump Question
Old Jan 12, 2011 | 10:40 AM
Talyn's Avatar
Talyn
The saginaw pump mod is a good mod if you do it.
Good flowing pump that doesn't whine like ours.
I have a link somewhere
*searches*
https://www.ford-trucks.com/forums/6...ering-fix.html
This is on a 150, so its probably not the same part number.
Old Jan 12, 2011 | 11:32 AM
superduty4x4's Avatar
superduty4x4
*searches*
One guy on page 4 said he did the mod on a PSD using that part number. He had to modify the pump bracket slightly but no other issues noted.
Originally Posted by StrokerJoe
I was able to convert my PS pump on my 97 F-350 with the 7.3L Powerstroke to the 20-6244 Saginaw pump. I picked it up at Napa for just under $100 dollars with a core exchange. I have to admit my stock Ford PS pump worked well and it was not a whiner like a lot Ford pumps tend to be. My reason for converting was to have strong and powerful pump for my Mile Marker winch. My stock Ford pumped worked well for steering my truck, but I needed a pump that I know is up to the task of putting out enough power to get the most out of my winch, and I don't feel my stock Ford PS pump can do what the Saginaw can. I had this winch on a 91 F-250 with a 351 before this truck and that pump was a whiner and did not seem to put out the power needed get full power out of the Mile Marker winch. So figured it would be best to swap in the Saginaw PS pump on my current truck that is known to be strong and reliable and definitely will put out more power to run my winch. My original plan was to swap in an AGR pump that fits the old Saginaw ham can, but I could not find any info on doing this on the 7.3L Powerstoke in the OBS trucks and was not sure what modifications I would have to do to make it work. Finally sourced out my answer from Performance Steering Components that using the Saginaw pump in the ham can would not work on the Powerstroke since it will not clear, but they make a conversion kit to use the Saginaw type pump on the Powerstroke that uses an external reservoir for the fluid for about $500dollars. At about the same time I discovered the 20-6244 Saginaw pump made to replace the Ford PS pumps on older Ford trucks. I heard of a lot people using this on a wide variety of years and motors in Ford trucks and it has pretty much the same shape as the stock Ford PS pump used throughout several years on most Ford cars and trucks so I figured it should work on the Powerstroke too even though I have not heard of anyone converting their PS pump on a Powerstroke engine to the 20-6244 pump. Maybe I'm the first, but I found out first hand that it does fit. I did have to modify my PS pump bracket in order to get it to fit, but it was not too involved to do. The stock Ford pump has nubs that stick out for the mounting holes and the 20-6244 Saginaw conversion pump has a horse shoe bracket mounted to the front of it so that it will mount up to your existing PS pump bracket, and horse shoe does not clear a protrusion on the right side of the PS pump bracket, but this can be can cut back and then the pump will fit. It does not sound like this has to be done on other brackets for the gas engines, but in order to get this pump to fit on the bracket that is on the OBS Powerstrokes you have to modify it slightly. My serpentine pulley fit just fine on the 20-6244 pump. You will need a pulley puller to remove the pulley from the stock pump to re-use on the new pump. The 20-6244pump comes with the tool needed to press your original pulley onto it. You will need a different pressure line, and this goes for the trucks with gas motors to from the 90's and assume most 80's too. I think the older trucks in the 70's used a different fitting on the pressure line that fits onto their pumps, and I believe the 20-6244 pump takes that fitting. Being that I have the Mile Marker winch, it replaces your pressure line with a line that has threads for putting on different fittings, and in the kit I got with the winch it came with a couple different fittings and one of them happened to be the correct one to fit the 20-6244 pump pressure fitting. I've been running this pump for a few days now and so far it's been great, and the steering is smoother and easier. I don't have the winch hooked up to it yet, but should here shortly and anxious to see how it performs under this pump.
Old Jan 12, 2011 | 11:57 AM
fishmanndotcom's Avatar
fishmanndotcom
long story short i tried doing this (dont recall the exact part number) and installed a pump that looks identical to those posted, but i couldnt get the pulley mounted all the way without it hitting the bracket.
i still have the pump so when i get home i am going to look at the part number.
-cutts-
Old Jan 12, 2011 | 02:13 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Cutts, can the bracket be modified for the pulley???
Old Jan 12, 2011 | 02:45 PM
evans213's Avatar
evans213
according to the big qoute it sounds like all that needs to be done is a "protrusion sticking out" needs to be cutt back and all will fit if I am wrong please correct me
Old Jan 12, 2011 | 02:52 PM
superduty4x4
Some minor grinding on the pump bracket to remove a protrusion and a different pressure line.
Old Jan 12, 2011 | 06:47 PM
evans213's Avatar
evans213
ok thats sounds easy enough I believe I am going to stop by napa tomorrow and see about getting one
barko4
31
Apr 22, 2024 06:55 PM
CountryBoy685
13
Jun 30, 2019 10:38 AM
autoxtech
16
Dec 5, 2010 06:49 PM
landdesigns
2004 - 2008 F150
Jul 24, 2010 04:22 PM
aj5601
1978 - 1996 Big Bronco
Sep 18, 2002 12:05 PM
