window
Old Jan 4, 2011 | 11:04 AM
jmikeyj4's Avatar
jmikeyj4
window
im wondering how to take out the window transmission on my 79 f-150 and how to put a new one in??????
Old Jan 4, 2011 | 11:28 AM
Joseph69's Avatar
Joseph69
Do you mean window regulator? It has rivets that have to be drilled out and then you bolt in the new one, not that difficult.
Old Jan 5, 2011 | 10:00 AM
jmikeyj4's Avatar
jmikeyj4
i think like where the handle crank for the window screws in cause thats all stripped out and i cant put the handle back on
Old Jan 5, 2011 | 10:07 AM
Joseph69's Avatar
Joseph69
Ford F Truck F100 F250 F350 73-81 Window Regulator LHS
It is going to be all one piece.
Old Jan 5, 2011 | 10:15 AM
Justin's Green Truck's Avatar
Is the gear/splines that the window crank fits over stripped out or is it the threads that the window crank screw goes in to that is stripped out?
Old Jan 5, 2011 | 04:02 PM
jmikeyj4's Avatar
jmikeyj4
the thread where the window screw goes is stripped
Old Jan 5, 2011 | 04:18 PM
650's Avatar
650
I don`t think it would work but you could try to tap and die it slightly larger so it would fit. If not you`ll have to as stated above drill out the three rivets or unscrew the 3 bolts. I forget what else you have to remove to get it out of there.
blazinjames
Mar 3, 2017 10:46 PM
centralNH
Apr 25, 2014 06:43 PM
NtShade
Mar 5, 2012 04:15 PM
JethroF250
Nov 11, 2008 08:56 PM
breakfastpoo
Aug 5, 2006 03:00 PM
