Window Lock?
Old Nov 10, 2008 | 07:03 PM
JethroF250's Avatar
JethroF250
Question Window Lock?
Tired of passengers messin with the window while riding. can i rig a toggle switch on the window switch panel as a window lock? if so how is it done?
Old Nov 11, 2008 | 01:37 AM
foxracing0934's Avatar
foxracing0934
I dont know if you can but i too would love to solve this issue. Damn little cousins messin with my stuff. lol
Old Nov 11, 2008 | 01:48 AM
immastrokinnow's Avatar
immastrokinnow
i would assume you could. maybe run the wires through a regular flip switch and mount on the dash.
Old Nov 11, 2008 | 02:00 AM
foxracing0934
I guess that makes sense. Splice into the power wire for the passenger window and then just put a toggle switch so when the switch is on power is will go to the window switch.
Old Nov 11, 2008 | 02:27 AM
immastrokinnow
hey jethro, did that downpipe help you at all?
Old Nov 11, 2008 | 02:37 AM
884x4broncoII's Avatar
884x4broncoII
id have to check what all the fuse for the power windows runs but you may just be able to put a toggle on the wire comming from the fuse and mount it somewhere convent for you
Old Nov 11, 2008 | 06:28 AM
Cuda_jim's Avatar
Cuda_jim
Don't know if it will help but the crew cab comes with a window lock switch. I guess that means the wiring is already there you just need to figure out what to tap into. IDK
Old Nov 11, 2008 | 07:00 AM
c00nhunterjoe's Avatar
c00nhunterjoe
jethro, yours is easy since you only have one window to lock out, i can give you the wire color and all you have to do is cut the wire under the dash and splice a toggle into it.
Old Nov 11, 2008 | 08:13 AM
JethroF250's Avatar
JethroF250
ok c00n thanks. i'm gonna put the switch on the door under the door lock switch.
strokin the dp will help i havent been able to get to c00n's house yet to check the dp that he has. thanks guys for all the help
Old Nov 11, 2008 | 08:56 PM
joe_13894's Avatar
joe_13894
Interesting... my truck came with a lock switch. It disables the passenger window controls but leaves the driver switch functional.
You'll need to get the wiring diagram. I'd help... but my shop CD died. The switch interrupts the power or ground only for the passenger switches; I just can't remember which.
Texas Chain Ring
26
Jan 13, 2013 11:29 PM
reamer
Oct 23, 2011 01:56 PM
stm250
Oct 19, 2007 09:58 AM
00GT
Apr 27, 2007 11:34 AM
