ECM failure
Old Jan 3, 2011 | 07:24 PM
Bamablue's Avatar
Bamablue
ECM failure
Hey Guys I wanted to throw this diagnosis out there to see if it makes sense. f250 diesel 140k. Started up after sitting 7 day in cold weather (lows below freezing, cold for FL) anyway zero power. Drove to ford dealer and they are throwing a $2500 repair at me. They indicate that i have a bad injector (electrical portion of the injector) that has shorted out the ecm. Does this sound right. It seems real fishy to me.
Thanks
<!-- / message -->
Old Jan 3, 2011 | 07:30 PM
bismic's Avatar
bismic
Get them to tell you (or show you) the code(s). Are they saying a harness shorted out or the short is in the injector?
Doesn't sound right to me.
Old Jan 3, 2011 | 08:24 PM
Bamablue's Avatar
Bamablue
To the best of what i could understand I would say the injector shorted. He said the injector shorting out caused the ecm to go.
Also, I had just plugged my truck up for the first time ever (to extension cord for cold weather). Could this have caused a short.
Old Jan 3, 2011 | 08:32 PM
bismic's Avatar
bismic
Who knows what can happen w/ electrical shorts. Maybe a Tech can jump in and comment on the ECM issue.
Old Jan 4, 2011 | 12:24 AM
moebdick's Avatar
moebdick
The injectors connect to the FICM. Seems odd that a short could take out the ECM/PCM but not damage the FICM.
Old Jan 4, 2011 | 06:43 AM
69cj's Avatar
69cj
Not saying it can't but, this would be a first that I have seen on this forum for an inj. to take out an ecm.
Old Jan 4, 2011 | 09:44 AM
dchamberlain's Avatar
dchamberlain
IF the ECM was "shorted out", I kinda doubt the truck would even run.
I think you need to take it to a different mechanic and get one that can explain things that make sense.
Old Jan 4, 2011 | 06:42 PM
cheezit's Avatar
cheezit
Call and ask to talk to the tech. I think the advisor has some wires crossed.
Old Jan 4, 2011 | 06:46 PM
gearloose1's Avatar
gearloose1
It ain't wires.... it is the loose screws.
Gord's-Fords
Apr 5, 2015 06:26 PM
kennyr
Jul 9, 2011 11:25 PM
Bamablue
Jan 3, 2011 07:20 PM
wescon
Aug 21, 2010 05:00 PM
skarwinski
Oct 16, 2008 05:54 PM
