Sponsored by: Real Truck
ECM failure
Old Jan 3, 2011 | 11:11 AM
Bamablue's Avatar
Bamablue
ECM failure
Hey Guys I wanted to throw this diagnosis out there to see if it makes sense. f250 diesel 140k. Started up after sitting 7 day in cold weather (lows below freezing, cold for FL) anyway zero power. Drove to ford dealer and they are throwing a $2500 repair at me. They indicate that i have a bad injector (electrical portion of the injector) that has shorted out the ecm. Does this sound right. It seems real fishy to me.
Thanks
Old Jan 3, 2011 | 11:47 AM
senix's Avatar
senix
what year/motor do you have?
personally I have never heard of that. I take it that you are out of warranty.
Old Jan 3, 2011 | 02:50 PM
Bamablue's Avatar
Bamablue
04 year model with 6.0 L
Old Jan 3, 2011 | 03:20 PM
senix's Avatar
senix
I think I'd be getting a second opinion. I find it hard to beleive.
Old Jan 3, 2011 | 05:26 PM
Bamablue's Avatar
Bamablue
Thanks. It just doesn't sound right. He explained to me that power comes from battery and/or alternator to the ecm where it is changed from 12v to 50v and then powers the injectors. he stated that the short in the injector fried the ecm. He also said i need a pressure regulator.
I plugged my truck up (heater) for the first time during this cold snap. (I didn't even know that i had a plug til someone showed it to me). Is there anyway that could have caused something?????
Old Jan 3, 2011 | 06:43 PM
senix's Avatar
senix
I am not an expert on the 6.0..well none of them really. 6.0 injectors are fired by oil pressure so does not seem to me that electrical gets to the injectors.
Best to slip down the the 6.0 section and see what they say
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Jan 3, 2011 | 07:10 PM
F350-6's Avatar
F350-6
Run away from that dealer as fast as possible. If the injector solenoid went bad, it didn't take out the ECM and shouldn't take out the FICM either.
How rough does the truck run? At this point, I'd also suspect weather you really have a bad injector solenoid.
Old Jan 3, 2011 | 07:20 PM
alwayschooseford's Avatar
alwayschooseford
I'm pretty sure that injector drivers are external to the ECM. In gas engines they are integrated though. Not positive, I know they are on the 7.3s and I think it is like that on all ford diesels. I just replaced a bad injector driver in my ECM on my 5.4 so it is entirely possible that you burned up a transistor in the injector driver module. I replaced it for $1.60 from radio shack.
McCloud853
Mar 24, 2017 08:09 PM
Fordys54
6.4L Power Stroke Diesel
May 18, 2016 10:18 PM
Fordys54
May 16, 2016 05:07 PM
will2045
1978 - 1996 Big Bronco
17
Jan 31, 2012 03:12 PM
kennyr
Jul 9, 2011 11:25 PM
