Turbo question
Old Jan 3, 2011 | 07:12 AM
Roody727's Avatar
Roody727
Turbo question
What OS the easiest way to tell ehen my turbo is engaged? I am trying to see what is the maximium mph I can cruise at before my turbo spools. I have a-pillar gages. Any help?
Old Jan 3, 2011 | 07:29 AM
thomabb's Avatar
thomabb
Not quite sure what exactly you are looking for. The turbo is spinning on the 7.3 any time the engine is running. There is nothing that engages at a certain speed.
Old Jan 3, 2011 | 07:36 AM
Roody727's Avatar
Roody727
I am driving from Fla to Michigan right now and am trying to see if there is a point that triggers extra fuel consumption ... I can go about 75 before I go over 5psi of boost .... wondering if there is a point I should look at to help the mpg's ...
Old Jan 3, 2011 | 08:05 AM
thomabb's Avatar
thomabb
I'll tell you what I do for long highway trips. Cetane boost and a quart of 2 cycle oil per fill up. I try to keep the engine around 2000 to 2200 RPM and use the cruise control as much as possible on the flats. In the hills I don't use cruise control and I try to keep the tranny in OD as much as possible. I can get 25mpg this way.
You are a little heavier than me, but with your custom tunes this should work.
Old Jan 3, 2011 | 11:53 AM
Roody727's Avatar
Roody727
What does the 2-cycle do for you?
Old Jan 3, 2011 | 12:00 PM
thomabb's Avatar
thomabb
It helps keep the fuel side of the injectors lubed. It will make the engine run quieter.
When the refinery removes the extra sulfur to make ULS diesel, a side effect of the process makes the resulting fuel slightly less slippery. The fuel side of these injectors are lubed with the fuel.
For fuel efficiency, the bigger bang for your buck is probably the cetane rating booster.
Old Jan 3, 2011 | 12:43 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
if you only have 5lbs at 75 mph im willing to bet you have a boost leak.....
Old Jan 3, 2011 | 01:19 PM
Roody727's Avatar
Roody727
Indy ...2000rpm is 75mph for me .... under heavy acceleration my gages read 24psi .... normal?
Old Jan 3, 2011 | 01:40 PM
indyF-350psd
yeah that sounds ok guess i didnt notice its an X with 3:73's vs my 4:10's doing 64 at 2000 rpm's......
Old Jan 3, 2011 | 01:52 PM
Roody727's Avatar
Roody727
Whew .... scared me a little bit .... I'm also running 35's
Old Jan 3, 2011 | 02:32 PM
Servinghim's Avatar
Servinghim
So the main reason to put the 2 cycle oil in our tank of gas is just to lube those injectors?
Any real chance of long term damage putting that into ones tank?
Old Jan 3, 2011 | 05:28 PM
shadows4's Avatar
shadows4
Want to help the MPG's? Slow down! Works everytime!
Old Jan 3, 2011 | 06:07 PM
thomabb's Avatar
thomabb
No. 2 cycle oil is engineered for combustion chambers. The 7.3 will burn all kinds of fuel without mods. Lots of people dump their used motor oil through a filter then use it as fuel for these engines. Hence the term "oil burner".
comadvan
Aug 17, 2016 11:20 AM
Ciscogomez
Jun 3, 2015 10:49 PM
Dustin460
Sep 11, 2009 01:29 PM
WALJON
Jun 11, 2008 08:06 PM
KBell
Apr 18, 2007 09:12 AM
