6.0 stumbles
Old Jan 3, 2011 | 08:56 PM
gearloose1's Avatar
gearloose1
You are getting into an area of not my expertise...
Old Jan 3, 2011 | 09:14 PM
mixerdrvr's Avatar
mixerdrvr
This whole area is not of my expertise! Thanks anyway
Old Jan 3, 2011 | 09:28 PM
chadjones99's Avatar
chadjones99
Originally Posted by mixerdrvr
Would a bad icp make the truck not want to run right after half throttle??? Truck starts great, runs great to a point. will run 70 and has acceleration unless you get it to downshift and it gets up in the rpm range, then you get rpms and no acceleration!
sticky turbo ?
Old Jan 4, 2011 | 07:10 AM
Logan Harding's Avatar
Logan Harding
Good Morning Everyone!! New here to this site. Having the same issue that MixerDrvr is having. 73,000 on an 04 F-250. Only, when my eng. finally does kick in I here a clicking sound (CLICKS @5X) that sounds like it is near the rear of the eng. Tx for the Help!!
Old Jan 4, 2011 | 06:06 PM
chadjones99
could it be clicking in side the cab ?
Old Jan 4, 2011 | 07:08 PM
Logan Harding
Not sure of where. Did remove and clean EGR valve, very dirty. Drove only 14 mi. and ran good. I'll try those other items if this does not work. Tx again!!
Old Jan 4, 2011 | 08:32 PM
chadjones99
i had a clicking noise under the dash , in the center. by the radio area turned out to be a blicker relay, and it was caused by the blicker switch on stearing colum
Old Jan 9, 2011 | 03:37 PM
mixerdrvr's Avatar
mixerdrvr
Update
Truck died thursday picking gf up at airport. Will find out tomorrow or tuesday why and how much.
Chevota_72
87
Jan 16, 2018 02:41 PM
knutson28
Jul 23, 2014 03:34 PM
03KingRanchF250
Mar 22, 2014 02:51 PM
lmorgan63
Jan 8, 2014 06:51 AM
blue_mule
Dec 3, 2002 04:31 PM
