WASTE GATE ?
Old Dec 31, 2010 | 07:32 PM
SLAMMIN 22's Avatar
SLAMMIN 22
WASTE GATE ?
OK guys I think I read sometime where some of you have either shortened or lenghthened the rod to help the performance seems like may be it gave a little more boost if I remember right I am getting ready to do WW mod and thought I would check into it also Any advice?? thanks
Old Dec 31, 2010 | 07:35 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Do you have surge issues right now?
Old Dec 31, 2010 | 07:38 PM
SLAMMIN 22's Avatar
SLAMMIN 22
yes I do when pulling
Old Dec 31, 2010 | 07:43 PM
SLAMMIN 22's Avatar
SLAMMIN 22
When its cold out like it is now it almost feels like I have a dead spot in my throttle also you get the whooshing sound and then it will take off all at once.
Old Dec 31, 2010 | 07:45 PM
Izzy351's Avatar
Izzy351
If you're pulling the turbo to put in the WW, now is the time to tighten up the rod. I ran mine with the line pulled & plugged after putting on the WW -- no surge issues.
Old Dec 31, 2010 | 07:52 PM
SLAMMIN 22's Avatar
SLAMMIN 22
I wasnt planning on pulling it I know I should but seems quicker leaving it on
Old Dec 31, 2010 | 08:26 PM
Izzy351's Avatar
Izzy351
You certainly don't have to, but it would be easier in the long run for the wheel swap & rod adjustment...
Old Dec 31, 2010 | 08:56 PM
thordehr's Avatar
thordehr
Adjust your rod....
Clean all the threads on the rod and the rod end. Run it all the way down, short as possible. Do this with the actuator removed.
Disconnect line and plug it.
https://www.ford-trucks.com/forums/1...ore-power.html
Old Jan 1, 2011 | 07:00 AM
jetdoc's Avatar
jetdoc
That is called the EPBV...... Do a search and you'll find out all you need to know about it...
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
russellkr
Nov 2, 2002 11:18 AM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
