Sponsored by: Real Truck
Will not idle
Old Dec 30, 2010 | 06:11 PM
whitsitt3's Avatar
whitsitt3
Will not idle
Greetings,
I own a 1999 F250 super duty (5.4L). A few days ago it would not idle, but after a few attempts it ran and idled normal. Now, it will not idle at all. It runs good if I give it gas, but the moment I release the gas, the engine dies. My initial thought was the fuel filter, so I replaced it. Problem still exist.
After doing some research in these forums I think I might have the answer I need, but I thought I would verify this by posting my problem for a second opinion.
1. Idle Air Control valve
2. Throttle Position Sensor
Thanks
Old Dec 30, 2010 | 06:13 PM
alwayschooseford's Avatar
alwayschooseford
idle air control valve, try spraying it out with some throttle body cleaner (its on the back of the throttle body) and if that doesnt work replace it
Old Dec 30, 2010 | 06:24 PM
whitsitt3's Avatar
whitsitt3
Thanks for the rapid reply! Could you please give the precise location of the IAC?
Old Dec 30, 2010 | 06:40 PM
redford's Avatar
redford
FTE Leadership Emeritus
I know this isn't a 5.4L engine, but this shows a typical mounting location for the IAC valve.
Old Dec 30, 2010 | 06:44 PM
whitsitt3's Avatar
whitsitt3
Thanks redford. Hopefully this works.
Old Dec 31, 2010 | 03:12 PM
whitsitt3's Avatar
whitsitt3
Originally Posted by whitsitt3
Greetings,
Thanks
Ok. . . I replaced the IAC valve and the truck started first crank, and idles nicely. However, now another problem exists. There is a low hum of howling noise during idle and while driving, and when I let off the gas the engine surges until almost to a full stop. Is the black cap supposed to be loose?
Thanks in advance,
mike
Old Dec 31, 2010 | 04:04 PM
redford's Avatar
redford
I don't think so,
Old Dec 31, 2010 | 04:13 PM
whitsitt3's Avatar
whitsitt3
I don't think so,
What do you think is causing the noise and surging? The black cap can be removed, but stays on.
Old Dec 31, 2010 | 04:36 PM
redford's Avatar
redford
I am not sure. Not an IAC expert since my truck doesn't have one. I would try without the cap.
Old Dec 31, 2010 | 04:57 PM
whitsitt3's Avatar
whitsitt3
Tried without the cap and it didn't correct the problem, but it did idle rough. While I was under the hood I pin pointed the noise to be the hose connected to the back of the IAC and runs around to the front of the thottle body and connects there. Between the IAC and the where it connects into the air intake, there is a (don't know what to call it) baffle. When I pinch the hose, the noise goes away. Anyone????
MacPhly
Mar 18, 2015 08:06 AM
69 lil' Red Shane
Jan 24, 2014 10:31 AM
rvrunner
Modular V8 (4.6L, 5.4L)
Dec 10, 2007 05:28 PM
gearhead351
Mar 25, 2006 12:34 PM
sbauld
Oct 15, 2003 07:48 PM
