Sponsored by: Real Truck
Wierd Idle issues
Old Mar 16, 2015 | 11:27 PM
MacPhly's Avatar
MacPhly
Wierd Idle issues
2002 f250 5.4
When cold it starts no problem. In gear and go.
After warm up, I have to push the gas pedal to get it to start. After it starts, it idles up to 1500-2000 for a few seconds, then comes back down to normal idle. But some times it almost dies out (while in park).If I put it in gear while its idled up it will die immediately. If I let it idle back down and it doesn't die it will smooth out and then if I put it in gear it will stay running as normal and off I go.
Im thinking idle air control valve... but not sure.
My shift linkage on the column has been sloppy too... any chance thats related?
Thanks
Old Mar 17, 2015 | 07:14 AM
Tom's Avatar
Tom
Probably not the shift linkage, that's not related at all. Definitely sounds like an IAC valve. Telltale for that is being able to keep it running with the gas pedal. That's you doing what the IAC should be doing, and a sign it's not able to meter air into the manifold like it should.
Old Mar 18, 2015 | 08:06 AM
DavidB's Avatar
DavidB
captain2207
Oct 11, 2013 05:05 PM
RPEX
Oct 30, 2010 04:50 PM
leverettq5l4
Nov 26, 2004 12:02 PM
craneman74
Modular V8 (4.6L, 5.4L)
Oct 10, 2004 10:31 PM
91ExploXLT
Oct 6, 2003 12:27 AM
