Radius arms popping
Old Dec 23, 2010 | 12:52 AM
sncbluegt's Avatar
sncbluegt
Radius arms popping
My truck has a popping on both sides in the front end when I pull into any area that has some kind of ramp from flat ground if I pull in from the left then the left side does it and visa versa with the right side.
From inside the truck the popping is coming from right under whre the floor mat pins are....it appears to me that its gotta be the radius arms...my last truck never did this. Has anyone else had this popping in their truck? Honestly I think if the radius arms were loosened under load and the suspension jounced and then tightented back up then that would solve the problem...anyone???
Old Dec 23, 2010 | 01:36 AM
Rickx's Avatar
Rickx
No problems on mine. I have to go up about eight inches of curb to get in my driveway. Entering from either direction really slow each time and I have no noises.
Old Dec 23, 2010 | 06:27 AM
rickatic's Avatar
rickatic
X 2 If the neighbor is parked on the street, my cc sb can not make the turn into my driveway w/o rolling over the curb. I have not noticed any popping noises.
Old Dec 23, 2010 | 06:58 AM
BRUTUSIII's Avatar
BRUTUSIII
I had the same problem on my '10. It was in the shop twice and they said there was nothing wrong with it.
Old Dec 23, 2010 | 08:18 AM
PowerStrokeHD's Avatar
PowerStrokeHD
Old Dec 23, 2010 | 08:26 AM
Y2KPSD's Avatar
Y2KPSD
Body Mount
Body Mount is also my guess.
My 2000 had this issue also.
Turning onto a driveway that decended into a parking lot.
Body twist...
Pop under floor, took awhile to identify...
I just stopped going there for AM coffee (Coffee shop raised prices ), never happened again.
Old Dec 23, 2010 | 10:22 AM
kper05's Avatar
kper05
I don't notice any poping noises driving up and/or over something but I can hear and feel a pop under my feet (driver side floor board) when making a left turn; sometimes. The turn I notice it the most driving to work is flat ground.
I don't have an issue with my driveway which has a ramp and I'm turning in at an angle (left wheel is on the ramp while the right tire is in the gutter) and I have no issues with that.
No issue on non-paved roads so far and you would think that's where it would happen the most vs. a flat paved road. I've stopped paying attention for the most part and I don't remember an occurance this morning so I'll pay attention to it again.
Old Dec 24, 2010 | 12:09 AM
sncbluegt's Avatar
sncbluegt
Originally Posted by PowerStrokeHD
More likely to be the body mounts... Check out the attached TSB...
That is exactly what the truck is doing...Ill take the truck in and bring that TSB with me.. Thank you very much!!
Body twist...
Yup exactly what is happening to me..minus the coffee part
frederic
Jul 16, 2021 09:01 PM
plilikoi
Bronco II
Feb 3, 2010 03:19 AM
oem78
Jul 10, 2009 08:28 PM
Boss_358
Sep 4, 2002 09:57 AM
marriedguy1
Offroad & 4x4
Jan 5, 2002 03:48 AM
