2006 Power Window Problem
Old Dec 18, 2010 | 07:40 AM
Gordon0352's Avatar
Gordon0352
My driver's side window switch began working sporadically. If i held the switch down long enough or pushed down hard enough it would work. After months of this all windows stopped working. I replaced the #401 (30-amp breaker) but they still dont work. What now?
Old Dec 18, 2010 | 11:46 AM
sandrat's Avatar
sandrat
Would the window move very slowly or did you have to press very hard on the switch but then the window would run up or down at normal speed?
Old Dec 18, 2010 | 12:47 PM
Gordon0352's Avatar
Gordon0352
Sometimes, not always, if i pushed on the window button nothing would happen. But when the window did move - it was at normal speed. Happened randomly. After several months of this i got in started the engine and none of my windows work.
Old Dec 18, 2010 | 12:52 PM
Gordon0352's Avatar
Gordon0352
side note: My emergency brake warning light comes on sometimes - even if my brakes are fully released. weird !
Old Dec 18, 2010 | 02:19 PM
pepito113's Avatar
pepito113
I had the same problem. A few people on the forum reported the same problem. I had my window switch changed and that fixed the problem. Some people have removed the drivers side switch and cleaned out the contacts and is working fine. If you do a search on here you should come up with some hits.
Old Dec 19, 2010 | 04:38 PM
stanger_missle's Avatar
stanger_missle
My 2006 also suffers from this issue... Sometimes I have to push pretty hard on the switch to get the window to move.
I found this walkthrough that explains what causes this and shows how to fix it. It has lots of pictures and it pretty detailed.
http://www.f150online.com/forums/art...ow-switch.html
Hope this helps!
Old Dec 19, 2010 | 06:49 PM
Gordon0352's Avatar
Gordon0352
Wow!!! Thanks for the link. That was exactly the help I was looking for. You are the man !!!
Old Dec 20, 2010 | 07:39 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
Did this procedure on my 06 a few months ago; drivers window was intermittent and has worked fine ever since.
Scrape the contacts gently with a dental pick and apply light coat of anti-oxidant jelly, the kind used on bulbs and trailer harness connectors.
I used GROTE brand in a tube.
Old Dec 20, 2010 | 07:45 PM
efx4's Avatar
efx4
Hope this helps!
Great post!
dmddb
Aug 5, 2017 06:51 PM
juliomad
1997 - 2003 F150
May 22, 2017 07:28 AM
Dpan63
Apr 9, 2014 05:42 AM
teamlx88
Feb 2, 2014 03:34 PM
gyrospinup
1997 - 2003 F150
Sep 16, 2011 09:43 PM
