auto headlights
Old Dec 15, 2010 | 09:21 AM
chawkjr's Avatar
chawkjr
auto headlights
Hello I have a o3 x w/6.0 4x4 How do you adjust the auto headlights to turn off sooner after shutting down the vehicle, I have nothing on my rearview mirror and just have a dash dimmer on the switch
Old Dec 15, 2010 | 11:25 AM
Nosedive1's Avatar
Nosedive1
Look in the owners manual, I'm pretty sure that I have seen a method in there about how to adjust the time.
Old Dec 15, 2010 | 01:10 PM
Dan Reinbold's Avatar
Dan Reinbold
I didn't get an owners manual with mine, and I would like to make mine stay on longer. Anyone know the method or could help me out?
Sorry to Hi-Jack, but if I get my answer, it might help OP get theirs.
Old Dec 15, 2010 | 01:27 PM
jasonodsky's Avatar
jasonodsky
Linky to the manual...start on page 48
http://www.motorcraftservice.com/?li.../04hdwog2e.pdf
Old Dec 15, 2010 | 01:38 PM
jasonodsky's Avatar
jasonodsky
Should have just pasted this in here:
Autolamp control (if equipped)
The autolamp system provides light
sensitive automatic on-off control of
the exterior lights normally
controlled by the headlamp control.
The autolamp system also keeps the
lights on for approximately 20
seconds after the ignition switch is
turned to OFF.
To change the delay time of the autolamp feature, do the following:
1. Start with the ignition in OFF and the autolamps selected.
2. Deselect the autolamps.
3. Put the ignition in RUN.
4. Put the ignition in OFF.
5. Select the autolamps. Steps 2 through 5 must be performed within a
10 second period. At this point, the headlamps and parking lamps will
turn on.
6. Deselect the autolamps after the desired autolamp delay time
(maximum of 3 minutes). At this point, the headlamps and parking
lamps will turn off.
Old Dec 16, 2010 | 12:56 PM
RACERX7775's Avatar
RACERX7775
anyone know if the auto lamp feature can be added? My 01 doesnt have em but the headlight switch can easily be changed.
Old Dec 17, 2010 | 07:55 AM
Dan Reinbold
turned to OFF.
turn on.
Thanks, Reps your way!
Old Dec 18, 2010 | 02:25 AM
TYZ78F150's Avatar
TYZ78F150
RACERX7775,
It will require the sensor to be installed and the switch. I'm sure there is a relay in there too.
Old Dec 18, 2010 | 07:43 PM
RACERX7775's Avatar
RACERX7775
TYZ, i kinda knew that. I was wondering if the system could be added by. Or if it can just be plugged in to the harness somewhere. Thanks anyway though.
4fords
Electrical Systems/Wiring
Jul 16, 2014 02:17 PM
yenrod
2004 - 2008 F150
Mar 15, 2014 05:47 PM
Enomra
2004 - 2008 F150
Oct 28, 2012 09:32 PM
wyobob
Sep 3, 2010 03:51 PM
5xkmw
Dec 26, 2007 09:30 PM
