5.4 Excursion Temp creeping up
Old Dec 17, 2010 | 06:55 PM
2FordTrucks's Avatar
2FordTrucks
My wife called this evening and said the temp needle was up above the middle mark. She said it was driving just fine. So, besides the normal thermostat and checking water and oil level what have you expierenced excursion owners run across? It is a 2000 2wd with the 5.4 and it has 141k on it. We just took a long trip in it last weekend and did not notice it creep up or any driveability issues. I did notice on day this week when she started it it had a slight knocking noise but that was on the morning it was 17 in the morning but no noises since. I hope it is not on its way out. She really likes this thing.
Old Dec 17, 2010 | 09:30 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
fan clutch.or lazy thermostat.=could cost you a engine.
Old Dec 18, 2010 | 06:49 AM
2FordTrucks
She was looking at the oil pressure gauge. Temp was fine. I did notice the oil was a little low. Halfway between full and add a quart. It is time for a oil change. Looks like we have a burner. Going to switch to a heavier weight oil.
Old Dec 18, 2010 | 12:08 PM
jh818's Avatar
jh818
I wouldn't change to a heavier weight oil...and especially when it's cold out.
Old Dec 18, 2010 | 05:07 PM
cbradford's Avatar
cbradford
I wouldn't say it's a burner with the oil level halfway between full and a quart low.....just before due for a change.
Old Dec 18, 2010 | 05:27 PM
2FordTrucks
I was going to use 10w30. You guys think I should stick with the 5w30? If so, can you think of a additive that I should look at using?
Old Dec 18, 2010 | 05:45 PM
tdappleman's Avatar
tdappleman
Use the factory recommended oil weight and no additives would be my recommendation. Going to a heavier weight oil or using additives will just mask a problem and not actually solve anything. A heavier weight oil will potentially cause more problems down the road by making the oil pump work harder and having oil not flow correctly through the engine. BTW - going to a 10w oil vs. 5w oil just affects the viscosity of the oil at startup or when cold - at normal operating temps (~210*) the oil will still behave as a 30 weight oil. Make sure the oil is truly full when doing a change - it may actually hold more than you are pouring. My V10 says 6 qts with filter but actually holds closer to 6.5. Make sure you start after doing an oil change, do a leak check on the drain plug and filter and then shut down. After it sits for at least 2 mins then check again to see if any needs to be added.
Old Dec 18, 2010 | 09:11 PM
2FordTrucks
I was going to go with the heavier weight due to the age of the engine. Was told once that it will help older motors. It runs and drives just fine. I'm kind of shocked after all the doom and gloom I've been told about these 5.4 motors. I would like to see 200k out of before I have to do anything major to it. I may be dreaming though. Personally I wanted to find a V10 but the 5.4 was cheaper. Am shocked however at the performance and mileage over my sister in laws V10. Going to change the oil next week when I'm off. It will be the first oil change for me on this truck. We've had it 5 weeks now.
Courtney Williams
Apr 23, 2013 09:50 AM
jpcjguy
28
Jul 7, 2010 09:56 AM
jpcjguy
Jun 14, 2010 01:01 PM
lastxit
1997 - 2003 F150
Jun 2, 2010 06:00 PM
madcatter33
1997 - 2003 F150
Jan 1, 2010 07:59 AM
