Edge Insight?
Old Dec 11, 2010 | 09:10 AM
06NEWTOME's Avatar
06NEWTOME
thanks Zmann looks like i'll be calling on monday
thanks for all the help, Jeremy
Old Dec 11, 2010 | 09:22 AM
Zmann's Avatar
Zmann
I hope it works out // not the first I have read about so your not alone
most seemed resolved after a call to edge
Old Dec 11, 2010 | 09:35 AM
bpounds's Avatar
bpounds
Just to be clear, we are talking about the older original Insight, right? NOT the newer CT or CTS.
Old Dec 11, 2010 | 09:51 AM
06NEWTOME's Avatar
06NEWTOME
ya it is a original style, it confused me too when the disc it came with says insight on but it downloaded the fusion software too. when it is hooked up to the pc the insight software says no insight connected to usb port. but with the fusion software it will say that the 83400 has been detected and no new updates are needed. the screen of the insight ,dash unit, will change form red to greeen. but no text.
Old Dec 11, 2010 | 09:56 AM
teppler's Avatar
teppler
Mine did the same thing calll them and or e-mail and they can get it going with no problem.
Old Dec 11, 2010 | 10:00 AM
bpounds's Avatar
bpounds
It's normal to not see any text on the LCD when connected to a PC. Just a blank screen.
I have the instructions in PDF if anyone wants them. They are on your CD if you know where to look for them.
Make sure you are ONLY connected via USB, or ONLY connected to the vehicle cable, but not both at once.
If you have access to another PC, you might want to try installing the software. Especially if you can use a Windows XP machine. Anything USB can be flaky at times.
Be sure to use the USB cable that came with the unit, not a generic one. Connect directly, not through a USB hub, which might be a keyboard or monitor plug.
Not much help, I know. It's all I got.
Old Dec 13, 2010 | 06:00 PM
06NEWTOME's Avatar
06NEWTOME
called today and got me going in no time at all just needed some new software , great people to talk to. will be buying more from them again, off to Iowa now,
jeremy
Old Dec 13, 2010 | 06:04 PM
bpounds's Avatar
bpounds
Excellent. Have a safe trip.
mackdaddy1
Apr 24, 2014 09:10 PM
rtazz17
6.7L Power Stroke Diesel
20
Feb 22, 2014 10:55 AM
Special Ed
Dec 2, 2011 09:55 PM
Jayybird
Mar 14, 2011 03:26 PM
Curt's05
Jan 25, 2011 10:27 PM
