edge insight question
Old Jan 15, 2011 | 02:43 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
my screen is blank on my insight when connected to my truck. my computer still communicates with the gauge. is there a reset? anybody else have this problem?
thanks, curt
Old Jan 15, 2011 | 03:30 PM
FordMan35's Avatar
FordMan35
Sounds a bit like a problem I had back in August. I called Edge, and they comanded a "reboot" to my unit when hooked up to my computer, and it reset the unit, and has been working fine ever since. Hope this helps.
Old Jan 15, 2011 | 03:53 PM
ljutic ss's Avatar
ljutic ss
Your not by any chance turning the ignition off once the screen boots up and before you actually crank it over? If you turn the ignition off for example to recycle the glow plugs and then back on, once you start the truck you will get a blank screen.
Old Jan 21, 2011 | 11:44 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
fordman35, you were correct, the tech @ edge had to update my firmware, using
the fusion software! The tech's are very helpful & waited on the line while i was steered
to the program/setting! Thanks again!
Old Jan 21, 2011 | 12:14 PM
kh62685's Avatar
kh62685
Sorry I miss read ur problem i thought u wernt getting any power at all.
Old Jan 25, 2011 | 10:27 PM
FordMan35's Avatar
FordMan35
Glad to help
Curt's05
2015 - 2020 F150
Oct 10, 2019 05:24 PM
Curt's05
2015 - 2020 F150
Aug 23, 2016 06:43 PM
Curt's05
May 3, 2016 12:16 PM
Curt's05
Dec 12, 2013 09:44 PM
