intake exhaust installation ??
Old Dec 8, 2010 | 06:00 AM
randrford's Avatar
randrford
Im installing the intake and headers on my 79 F100 striaght 6 wondering bolt tightening sequence and torque spec any help would be much appreciated dont want any leaks ... Thanks !!
Old Dec 8, 2010 | 07:13 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Do not know them off hand try a search in the eng forum, but I do know to make sure you have no oil/grease on your hands/eng head/or header it can cause you to burn up that brand new gasket.
Use lots of anti-seize on the bolts, maybe up grade to grade 8 and make sure your bolt head has enough size to apply a spread torque on the header flange.
And consider some 2 piece lock washers with little teeth (called?) from Fastenal. And do a hot and cold torque ck, have a nice day.
Old Dec 8, 2010 | 05:28 PM
wyckedcombo17's Avatar
wyckedcombo17
Usaully you do exhaust manifolds from the middle bolts out in kind of N pattern first towards the rear of the engine then towards the front. According to my Haynes exhaust manifold to head is 28-33 ft lbs.; intake manifold to exhuast manifold is 28-32 ft lbs.; and intake manifold to head is 22-32 ft lbs.
Old Dec 10, 2010 | 02:35 AM
dulockdrumheller's Avatar
dulockdrumheller
I got maintenance manual at home will get you specs tomorrow. I just need your vin code!
daveyboy1
20
Aug 9, 2011 12:26 PM
KenLaffin
6.7L Power Stroke Diesel
Jul 15, 2011 10:55 AM
TexasTornado66
Jul 1, 2010 10:58 AM
mw1063
2004 - 2008 F150
53
Mar 27, 2005 05:21 PM
51truck
Aug 1, 2002 04:44 PM
