WHAT IS IT?
Old Dec 4, 2010 | 06:24 PM
m50's Avatar
m50
WHAT IS IT?
I have a 96 F-350 with diesel, on the driver side of the fuel filter can there is a sending unit that is leaking fuel. I have no idea what this is, can someone tell me what it is? So I can get the part to replace it.
thanks Ron
Old Dec 4, 2010 | 06:50 PM
Hussler's Avatar
Hussler
If it's this one it is called the "fuel filter vacuum switch", or something like that. It senses a vacuum in the filter when the filter becomes plugged up. They are a known problem for leakage out by the electrical connection. I think Ford current cost is about $50 and you can get the same part for about $25 from International ...
Old Dec 4, 2010 | 07:00 PM
m50's Avatar
m50
That is it! thanks for the info I didn't have a clue what it was.
RB
Old Dec 4, 2010 | 07:07 PM
Hussler's Avatar
Hussler
If you get one don't tighten it up to much. Just hand snug then maybe another half turn. You can easily crack the filter housing if to much torque is applied.
Welcome to FTE by the way ...
pjwoolw's Avatar
pjwoolw
In the mean time 1/8" npt plug from the hardware store will take care of it.
Old Dec 4, 2010 | 07:12 PM
tjbeggs's Avatar
tjbeggs
Edit- Too slow tonight
or unplug it, remove it and plug the hole with an 1/8 inch pipe plug. I have had some pretty nasty filters and never saw the light come on.
Old Dec 4, 2010 | 07:31 PM
m50's Avatar
m50
So it sounds like it is not needed. I change my fuel filter pretty regular with this bio-diesel. I have owned this truck for 10 years and never seen any light come on about the fuel filter.
Thanks for the help RB
Old Dec 4, 2010 | 07:33 PM
Fullcrew7.3's Avatar
Fullcrew7.3
x3 what Pete and TJ said.
Hughesjr84
Dec 27, 2013 12:55 PM
rstazick
Oct 3, 2007 08:07 AM
ron's power stroke
Jul 17, 2006 10:45 PM
GTO-Ron
May 1, 2005 05:03 PM
synergy46
May 27, 2004 04:37 PM
