Where to buy a Computer Controlled Camshaft?
I know the EFI engine is a little more finicky to cams, but they are out there. I'd recommend contacting the manufacturers directly and getting their opinion. I know Comp Cams has a section on their site specifically for getting recommendations.
COMP Cams® - Cam Recommendation Form
I've been running the crane 503901 for a while now in a 91 and was very pleased with the power increase. Only other mod at the time was a hooker header and duals, idles with 20" of vacuum. Always had an lc1 wideband with dash mounted guage and my afr's at idle and cruise did not change one bit, so im very confident recommending that cam for an efi motor. Since then I added a very nicely ported head with larger si valves and WOW what a difference. The head raised my WOT afr from 13.5 to 16.5 so Im definitly moving alot more air, in the process of new injectors and fpr now.
pcullins
10-21-2004 07:33 AM
