Auto Trans Linkage adjustment
Old Nov 29, 2010 | 02:40 PM
cannonman's Avatar
cannonman
Gentlemen. I have a 78 2wd AT C4 . After replacing the oil pan gasket and all that entails,the transmission would not go into park as it should. So I would start her up in neutral. Fine. Now I have adjusted the linkage to where everything lines up as it should. Turn the key to start and...nothing. No click. Lights and wipers come on. New starter. I go back down and tighten the nut to spec and she starts up right away. Cool.4 min later. Now she won't start again and the nut tightening trick isn't working either. Wont start in neutral,no click. Where do I begin?
Old Nov 29, 2010 | 06:16 PM
desperado_18_2000's Avatar
desperado_18_2000
Do you still have the neutral safety switch? It could be flaking out and causing the no start issue. That is what I would check to see if it is the problem or not.
Old Dec 2, 2010 | 01:59 PM
cannonman's Avatar
cannonman
Neutral safety switch it was. Thanx.
Daviddc114
Mar 20, 2011 08:30 PM
iron1951
Feb 18, 2011 06:39 PM
SpyFoxx
15
Jul 12, 2010 11:00 PM
Swatter
Dec 4, 2009 06:24 AM
