Sound dampers
Old Nov 28, 2010 | 03:38 PM
bkohne1's Avatar
bkohne1
Sound dampers
What have you guys used for sound damping? I have been researching it and have found alot of choices. The obvious answer is dynamat but it is way too exspensive..(i think) so im looking for some alternatives.
Old Nov 28, 2010 | 03:56 PM
HIO Silver's Avatar
HIO Silver
Jeg's has a kit similar to Dynamat but for less. Another alternative is Lizard Skin. IIRC, Lizard Skin has two types, sound control and the other is heat resistant. If using both, the SC is sprayed first. More preparation involved but we usually have more time than money, right?
Old Nov 28, 2010 | 03:57 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Myself im planning on rhinolining the firewall floor and inside back of the cab, then dynamat inside the doors back quarter and roof. Carpet padding has crossed my mind as far as a cheap alternative, but im not sure how well it will work.
Old Nov 28, 2010 | 05:10 PM
bkohne1's Avatar
bkohne1
Im looking to do the underside of the hood right now. I would like to stay away from the spray on styles.
Old Nov 28, 2010 | 08:13 PM
backyardbikes's Avatar
backyardbikes
if you want the best I would go for secondskin. Sound Deadening Materials for Noise Reduction from Second Skin.or if you want a slightly cheaper alternative look for some fat mat. second skin is the best ive used so far hands down. or you could go really cheap and use peal and seal. does the job. just starts to loose its adhesiveness after a while
brentkhack
Aug 7, 2014 11:24 AM
fordrules_2013
Oct 13, 2013 06:33 PM
hiwy50
Nov 5, 2006 03:58 PM
MARZ06
Modular V10 (6.8l)
Aug 30, 2005 12:43 PM
chipmunck
15
Apr 19, 2005 07:20 PM
