back pressure and size
Old Nov 17, 2010 | 11:54 PM
cs361's Avatar
cs361
My 79 has 2 1/14 inch pipe after the initial 2" comes down about 2 feet offthe manifold. Is it fine having the bigger pipe? And there is no catalytic converter. Will there be a loss of power or anything like that? Or damage to the engine?
Old Nov 18, 2010 | 12:12 AM
Rogue_Wulff's Avatar
Rogue_Wulff
The pipe should be fine. My 80 came with 2.25 from the manifold back thru the cat, muffler, and tailpipe, so 2.25 certainly isn't too big for a 300. I recently had it all replaced (except the first couple feet), and went 2.25 full length and flowmaster muffler. Works fine, and sounds even finer.....
Old Nov 18, 2010 | 07:13 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
FYI, the idea that an engine needs some sort of "back pressure" is a huge bunch of hooey. The exhaust should be big enough to not offer any restriction, but not so big you lose exhaust velocity and the associated scavenging effect.
Old Nov 18, 2010 | 09:52 AM
AbandonedBronco's Avatar
AbandonedBronco
Exactly.
Too small and the exhaust bunches up on itself and plugs up. Kinda like an interstate full of cars bunching down to two lanes.
Too big, and the speed slows down inside the pipe, and the exhaust behind it bunches up. Kinda like an 8 lane highway but everyone in front keeps slowing down and no one can get around them.
On mine, I have a 2.5" all the way back, and it works great.
Old Nov 18, 2010 | 01:38 PM
Rogue_Wulff
Perfectly stated. Even 2-3 PSI "backpressure" has a big negative effect on how an engine performs. An exhaust that is building pressure inside it, isn't flowing freely enough for an engine to breathe, therefore it's overall perfomance is reduced.
On the other hand, too large pipe, and the velocity is lost, which is key to helping to pull the spent air/fuel out of the combustion chamber. You don't want to rely solely on the push of the piston to get rid of the old gasses, making way for the new......
Old Nov 21, 2010 | 08:44 PM
cs361's Avatar
cs361
ok. so i shouldnt worry about not having a cat?
Old Nov 21, 2010 | 09:40 PM
hgb4x4's Avatar
hgb4x4
I run 2.5 all the way from the EFI manifolds... from past threads here that is about max you want to go tho. some even do duals at 2.5 with great results from what I read but need a ton of intake mods to do so.
The 300 has plenty of exhaust stock if no head work is done to it as thats the bigest issue with it is, the intake side IMO
stock for mine was 1 7/8 inch iirc? out the back. pre EFI
Old Nov 21, 2010 | 09:53 PM
Harte3's Avatar
Harte3
High-flow, 3-way Cats are available at a reasonable price and only necessary if you like a bit cleaner air to breath...and to meet Federal regulations if it was originally equipped with a Cat. Other than that, there is not enough difference to make a difference in back pressure.
Old Nov 21, 2010 | 09:56 PM
cs361's Avatar
cs361
yeah mines carbureted and from like the manifolds, about 2 feet down is stock (not sure what size exactly) then from there back, is 2 1/2" with no cat and a stock muffler. (new of course)
Old Nov 22, 2010 | 08:08 PM
cs361's Avatar
cs361
So as far as back pressure goes, i think i will be safe. hopefully
edreckers
Aug 11, 2015 04:13 AM
Anthonynoble
22
Mar 9, 2015 10:07 PM
FordPower92
Mar 1, 2015 06:26 PM
V10man
Modular V10 (6.8l)
Oct 14, 2014 06:04 PM
jgavac
Feb 25, 2013 11:43 PM
