H Pipe location?
Old Feb 25, 2013 | 09:15 PM
jgavac's Avatar
jgavac
H Pipe location?
Any ideas on where an H pipe would fit on a 2wd 79 250? I was thinking having the pipe go under the trans crossmember, but don't know how well that will work. Any ideas?
Thanks
Jameson
Old Feb 25, 2013 | 11:13 PM
xkpsanit's Avatar
xkpsanit
You are supposed the apply spray paint to the head pipes then drive her hard for awhile, it should be evident on the paint where your hottest spots are in the headpipes, then your x over should be located closest to them, then in theory, equalizing the highest pressure points.
Old Feb 25, 2013 | 11:31 PM
xkpsanit's Avatar
xkpsanit
Also, same diameter tubing and and maintain a perpendicular relationship to the headpipes ( H pattern) if you try to hit the hotspots perfectly with an angled pipe, you will be favoring one bank. Just get it close as possible.
Old Feb 25, 2013 | 11:35 PM
jgavac's Avatar
jgavac
I know how H and X pipes work.
Just to be clear, I'm not talking about headers. I'm talking about h pipes. I figured the closest I could get to the engine (what you're supposed to do with h pipes) is under the trans cross member
Old Feb 25, 2013 | 11:43 PM
xkpsanit's Avatar
xkpsanit
The want the x or h pipe to be in the highest pressure location on the headpipe. This is where they are the most efficient. But this doesnt always occur in the same spot side to side. .... i always overexplain myself, sorry
Fordenthusiasts
Mar 15, 2009 05:28 AM
cHiLi 11
6.4L Power Stroke Diesel
Sep 25, 2008 12:14 PM
ghunt
General Automotive Discussion
Jan 15, 2008 09:20 AM
KJKozak2
Exhaust Systems
Jul 30, 2002 12:32 PM
