can I get the egt too high in stock form?
I pull a dump trailer fairly regularly (2-3 times a month) when I do, I gross the scales from 22,000-27,000lbs and once as much as 33,000!... My truck is all stock.... I live in western pa and can get into some hilly terrain, which works the old girl... I make sure she doesn't dog down to keep the egt down.... gauges are on my list of things to do but not in a big hurry with the truck being stock... What do ya all think? Besides needing to buy a big dump truck....lol
I doubt it. I run about 24k-25k gross and in stock tune my egts might get around the 1200 mark or so which International says the engine can do all day long. I think a properly running stock 7.3 is pretty hard to overwork.
With a mild towing tune, I see 1350 on severe mountain climbs but it doesn't stay there long (even with the throttle pegged), the PCM must defuel after 15-20 seconds because my egts drop down to 1200-1250 or so when the truck settles into the maximum speed it will climb with that sort of weight. For my truck that is about 45mph on steep climbs.
I was always under the impression that in stock form the egt's would stay under control. However while pulling my camper to TX I saw 1450* one time with my DP in "stock"
Before then I really never paid any attention to the gauge in stock mode.
So unless I have other issues I guess you can see high egt temps in stock form.
I was in 60 tow for the other 95% of my trip, and I absolutely love that tune....
EDIT: after reading Gregs post, maybe I do have an issue?
Did your truck stay at 1450 for very long? I think a stock tune might get that high at the start of a tough climb but should settle down as you loose momentum. What normally happens with me is that I floor it at the bottom of the climb and the trans downshifts, then the egts spike when the engine feels the load. I usually just keep my foot in it and the egts settle down after 15 seconds or so.
I suspect there is something in the stock tune that allows high egts for a brief amount of time but then tapers off if you keep your foot in it. Maybe somebody will chime in who knows more about the tunes and confirms or corrects my suspicion.
While towing, have you noticed that your truck has plenty of power on steep climbs that are short in duration but doesn't seem to have the same sort of power on longer duration climbs, even if they aren't as steep? I've noticed that my truck pulls really well for the first 1/4 mile or so of a very steep hill, hardly loosing any speed at all then it's like it runs out of legs and begins to slow down. If you watch the pyro gauge, you will see the temps fall as your speed drops. At least this has been my observation and why I suspect the PCM is defueling somehow.
I am curious to know if anyone else has had similar experiences.
Honestly Greg, I dont think I stayed in it longer than 10 sec or so, It wasn't a huge hill, just a big bridge. Its possible that it would have defueled like you said.
I may be ok, There just isn't too many hills down here to do a good test. I'll keep an eye on the gauge on my trip home while in stock mode and see what happens.
...sorry
...sorry
Yes, still running the stock mixing chamber in the tank. I use DK every 4 or 5 tanks so I think that helps keep the screens clean. My fuel pressure is 62-67 and holds steady at 55-57 at WOT so I figure there is no reason to do the in tank mods.
So to answer the OP question, I would get a gauge on there ASAP. You dont know what your egts are until you know. IMHO it is cheap insurance. Hope this helps.
My pickup is stock as far as tuning, but I do have a 4'' exhaust. Even while I had stock exhaust pulling 23-24k, as long as I kept the rpms above 2200 my egt's would run about 1000*. If I let the rpms drop below 2000 then the egt's would run about 1150*. Rarely I would get close to 1200* on a long 6% grade, but it wouldn't stay there long.
Frank, I've had my pyro 'glitch' a couple times and give false readings - I pulled over and turned the key of and back on and it was normal...
I was gonna say that with 6spd it may be possible to lug it long enough to get hot - but there are other things that can lead to high EGT's. Restricted intake, restricted exhaust, up-pipe leaks, boost leaks, maybe fuel starvation... With a gauge, you know BEFORE its too late!!!
Haywire-Powerstroke
25
08-25-2015 09:28 PM
