rear leaf springs
Subscribe
Nov 12, 2010 | 05:06 AM
'81 F100 4700# GVWR
the stock springs are sagging badly and hardly support any weight. I'm looking for new replacement leaves. I know i need 2.5" wide springs but what you guys recommend? I'd like the rear to be a bit higher 1"-1.5" higher then the front and i'd like to pick up some load capacity without going to helper springs.
NDP? LMC? Rockauto?
WHere do you guys get your springs from?
Reply 0
Nov 12, 2010 | 10:45 AM
Junkyard!
I want to say you can pull the leaves from the years 1980-1996 f-150/f-100 2wd trucks only.
I got a set of leaves from a 1995 f-150 and they greatly helped it. It was basically a 2inch lift in the rear when i put them in. I also had some broken springs when i pulled it.
I was able to get both sides for only $75.00, and mine still had fresh black factory paint on them.
Reply 0
Nov 12, 2010 | 12:56 PM
i have been trying to put new parts where i can...i found them at bronco graveyard for $205 / pair. will also be replacing u bolts, leaf spring plates, shackles, and hardware.
Reply 0
Nov 12, 2010 | 04:17 PM
Ah, well if your wanting brand new id check out,
broncograveyard.com
natauto.com
LMCtruck.com
rockauto.com
Reply 0
Nov 14, 2010 | 12:40 PM
I replaced the old 4-leaf springs in my 85 F-150 4x4 with brand new ones from LMC. They cost me ebout a hundred bucks, plus I bought new bushings and shackles and u-bolts. I ordered the springs for the light-duty 3/4 ton trucks... A little wider and had an additional leaf. If you want to go all the way to a HD 3/4 ton rear suspension, you can order the same 5 leaf spring and then add the overload spring and frame stops. I pull a 16x8.5 foot enclosed trailer with mine, and it only lowers the rear end about an inch when I hook it up... Trailer has about 1500lb tongue weight.
Reply 0
Nov 14, 2010 | 12:46 PM
My truck is a small bearing 9", small bolt pattern, with 4700# gvwr. I want to be able to put more then 600# in the bed and have the bumper dragging the ground. Mid duty f150 springs are what I'm looking for. I don't do a lot of towing but occasionally haul gravel, mulch, etc....
Reply 0
Nov 14, 2010 | 12:49 PM
I would get the 4-leaf from LMC... The new springs should do just fine. I went with the 5-leaf because of the trailer, and because they were about the same price (maybe $10 more)
Reply 0
Nov 14, 2010 | 12:54 PM
Actually, depending if your truck is a 2 or 4 wheel drive... LMC only lists a 5-leaf for the 2 wheel drive models...
Reply 0
Explore
Nov 14, 2010 | 12:55 PM
Lmc's are $170/each...bronco graveyard has the same weight rated ones for $205/pair
Reply 0
Nov 14, 2010 | 12:58 PM
You might want to call LMC about that... I think I only paid $149 for the pair...
Reply 0
Nov 14, 2010 | 02:19 PM
Latest LMC catalog (FD.24 fall 2010) arrived about 2 weeks ago, and it shows the 2wd leafs as $129 and 4wd $149. Both show that you need 2 each, but coils and leafs are *typically* sold in matched pairs, so I would certainly call to clarify before ordering.
BTW, F100/F150 2wd uses 2.5" wide leafs, while the 4wd F150 and 2/4wd F250 both use 3" wide leafs. Converting to the 3" leafs would require both front/rear hangers and the shackles be changed. Lot of extra work and part cost that can be avoided, unless they all need replaced anyway.
Reply 0
Nov 14, 2010 | 02:23 PM
Check Ford Truck their service is top knotch
Reply 0
Nov 14, 2010 | 02:30 PM
Quote: Check Ford Truck their service is top knotch
Am I blind, or do they just not list anything for 2wd F100/F150 between 80 and 85?
I see 73-79, and 86-96. The 80-85 *should* be the same as the 86-96, but they skipped a few years there......
Decent pricing, though.
Reply 0
Nov 14, 2010 | 04:26 PM
JcWhitney also has a selection of custom springs, rather than the stock ones used on F150's.
Reply 0
Nov 14, 2010 | 06:24 PM
I get all of my brand new springs from Espo. Just call and tell Laura, I believe, what you want. They can even make them taller or shorter if you want.
Welcome to the Frontpage | Springs N' Things
Reply 0
Subscribe
