Vibration while driving...???
Old Nov 7, 2010 | 11:12 PM
my73f100's Avatar
my73f100
I bought my truck in March, been driving it ever since have had few problems... The other day I got in it and was driving home from work and it started vibrating pretty badly. But it would only vibrate over 40 miles per hour and only when I hit the gas. I am stumped. Anyone have any ideas...?
Old Nov 7, 2010 | 11:31 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Is it 40mph no matter what gear the tranny is in, including neutral?
We'll need to know if it's ENGINE speed or ROAD speed the vibration occurs.
Josh
Old Nov 7, 2010 | 11:59 PM
mdr617's Avatar
mdr617
I have the same problem with my 79 f100 2wd. but for the most part, the steering wheel shakes back and forth only when i hit the brakes, if im doing over 30mph...I thought it might have been ball joints, but i cannot find them anywere for 2wd, only 4wd. Do the 2wd's have ball joints? Could it be tie rod ends?
Old Nov 8, 2010 | 01:54 AM
Fordman18's Avatar
Fordman18
I recently had the shakes between 40 and 50 mph on acceleration. Crawled under the truck, and the double cardan on my drive shaft was too hot to touch. Unfortunately there wasn't much I could do, since the PO felt it was necessary to weld the u-joint caps in. Just had to fork over the dough to have a new drive shaft built, needed to have it lengthened for a lift anyway. I would check out your u-joints, and cardan (if applicable) for smoothness in rotation, and rear end for play.
Old Nov 8, 2010 | 03:23 PM
my73f100's Avatar
my73f100
Josh
I actually dont know if it is engine or Road speed. I'll have to check when I get off work, I'll let you know.
Brandon
Old Nov 8, 2010 | 03:31 PM
mdr617's Avatar
mdr617
mine is at road speed, and it has new u-joints and all new brakes
Old Nov 8, 2010 | 06:11 PM
Friesian-Bronco's Avatar
Friesian-Bronco
Holy smokes! The heat couldn't have been good for the bearings... but even barring that, What do people think when they do this stuff??
Old Nov 10, 2010 | 02:04 PM
f35074's Avatar
f35074
I had a similar problem and it ended up being a bad tire. I thought I had looked at them good, but there was a small bulge that was very difficult to see until you got the tire off the truck.
Old Nov 10, 2010 | 04:53 PM
my73f100's Avatar
my73f100
Josh
it seems to be no matter what gear the tranny is in. But 3rd and 4th gear are the worse. and its only if i am actually have my foot on the gas. but it doesn't do it in neutral... i really have no idea what it is...
Old Nov 10, 2010 | 07:05 PM
Bullitt390's Avatar
Bullitt390
Sounds like a clutch problem. Either the actual clutch or the input bushing.
Josh
Old Nov 10, 2010 | 07:14 PM
John in AZ's Avatar
John in AZ
Yours sounds like bad brake rotors. Either warped or have hot spots.
JOhn
Old Nov 12, 2010 | 12:33 AM
my73f100's Avatar
my73f100
Josh
thanks i'll look into it.
Old Nov 12, 2010 | 03:47 AM
mdr617's Avatar
mdr617
thanks john
Old Nov 13, 2010 | 06:52 PM
my73f100's Avatar
my73f100
Josh
It ended up being a u joint...the only reason i know this is because it snapped and my drive shaft fell out while i was driving. i took the drive shaft out in the middle of the road and limped back to my house in four wheel drive, on the plus side no more vibration.
next question... is there anyway i can make sure my drive shaft is still straight on my own...???
Old Nov 13, 2010 | 10:35 PM
Bullitt390's Avatar
Bullitt390
Well.. I guess that's one way to narrow down the problem!
A driveshaft shop would likely check the run-out for free or a very small fee.
Josh
TMF89
1997 - 2003 F150
Aug 9, 2011 03:48 PM
rh428wf
Aug 26, 2010 02:32 PM
jason1
1983 - 2012 Ranger & B-Series
Nov 18, 2008 06:03 PM
kenneBF250V10
May 15, 2008 07:48 AM
ziptie
Jun 28, 2003 05:50 PM
