vibration
Old Jun 16, 2003 | 09:00 PM
ziptie's Avatar
ziptie
vibration
I have a 95 F-150 that has a bad vibration in the 45-50mph range. It is only felt under normal driving. If I accellerate quickly I don't feel it. Replacing the tires and rims made no difference. I read the previous post concerning vibration, but my problem is a little different. I thought one of you may have had the same problem in the past. Any help is appreciated.
Old Jun 16, 2003 | 10:40 PM
Ryan50hrl's Avatar
Ryan50hrl
vibration
did you check the u joints first off. Secondly check how the tranny fluid and gear lube in the rear end look. if either of those look bad theirs a possibility that theres some mechanical failure eminnent in one of them, but remember, cause the fluid looks good doesn't mean there isn't still something wrong with them. But its a start.
Old Jun 20, 2003 | 08:27 AM
SawZall's Avatar
SawZall
vibration
Does your truck have a carrier bearing on the driveshaft? If the mounts are worn this could cause your problem.
later on
sawzall
Old Jun 22, 2003 | 08:10 PM
SawZall's Avatar
SawZall
vibration
hey thought of something else.
The transmission mount maybe bad since you don't feel the vibration when you floor it. The transmission maybe rocking in its cradle. Or one of the motor mounts could be bad.
Old Jun 23, 2003 | 01:32 PM
mr.tiny3's Avatar
mr.tiny3
vibration
Where do you feel the vibration? Front? Left?
Old Jun 28, 2003 | 05:50 PM
ziptie's Avatar
ziptie
vibration
I don't feel the vibration coming from any particular area. It feels like the cab is shaking left to right. I have replaced the u-joints and checked the fluid in the rear end. I have not checked the motor or tranny mounts. There seems to be a lot of slack around the yoke of the transmission, but I don't know how much is too much.
MattP84
Jan 19, 2012 04:17 PM
Truck Man1
6.4L Power Stroke Diesel
Jan 29, 2011 06:52 AM
09 Razor
2009 - 2014 F150
Jan 18, 2010 09:37 PM
MSC
Feb 10, 2006 08:20 PM
august
Mar 2, 2002 09:20 PM
