High Idle Mod A+
Old Nov 8, 2010 | 04:02 PM
  #31
TheBestKindOfEX's Avatar
TheBestKindOfEX
I read somewhere (trying to find it) that all of the trucks have the same wiring harnesses. I have located the upfitter wires under my dash and in the engine compartment.
Old Nov 8, 2010 | 04:48 PM
  #32
southbound35west's Avatar
southbound35west
i dont mean to hijack , but i have done this same upfitter switch and high idle mod install on my 2006 f250, but i just had an egr delete kit installed , so do i still need to flip the high idle on with an egr delete installed? since i have no egr to clog any more do i need to still idle high rpms when in park?
Old Nov 29, 2010 | 12:33 AM
  #33
SFC-REMF's Avatar
SFC-REMF
Anyone try the mod with just the e-break and no switch on a 04? Just wondering if the wire colors are the same? Did some searching and saw no orange wire.
Old Nov 29, 2010 | 06:00 AM
  #34
havns3's Avatar
havns3
I got the latest reflash done when i had my ficm replaced and now my truck goes to a high idle after sitting for a few minutes it only does it when the temps are lower say around 35 to 40 and it only does it when the ECT is between ambient air temp and 170. surprised the hell out of me the first time it did it. but it idles up to about 1000 rpms shuts off after you step on the brake. e brake is not engaged.
Old Nov 29, 2010 | 10:09 AM
  #35
texans's Avatar
texans
I have done this on serveral trucks (5). It seems that some you have to press in the e-brake some you don't. Doesn't matter how it is hooked up. I'm not real sure what makes it one way or the other. If it goes by year, or flash, or what?
Old Nov 30, 2010 | 04:54 PM
  #36
billbot's Avatar
billbot
My truck was iced over for the first time yesterday morning (bought last spring) and when the RPMs jumped up I was surprised.
With trucks that have a recent flash that sends RPMs to around 1k on cold mornings is the high idle mod necessary?
Old Nov 30, 2010 | 09:46 PM
  #37
pw1926's Avatar
pw1926
07 f350
can someone email me the instructions for 07 350 instalation ts02paul@gmail.com
i dont have the aux switches so also include what i need to do to add a small toggle switch under dash
thanks
Old Nov 30, 2010 | 10:02 PM
  #38
Misky6.0's Avatar
Misky6.0
Ok, that makes sense now.
While in NC last weekend, it was 30* in the morning
while packing up, I had the Ex running to warm up.
I noticed the idle kicked up to 1k also. I was stunned,
I thought something bad was going on.
(gee maybe the parking brake was on too?, not sure now)
*IF* it gets into the 30s this winter I'll pay more attention.
Old Nov 30, 2010 | 10:53 PM
  #39
ford7379trucks's Avatar
ford7379trucks
i have a 03 with 12/03 flash and mine gos to 1000rpm automatically when cold. I put my hi idle on a switch so I have complete control of it.
Old Dec 1, 2010 | 02:19 AM
  #40
TheBestKindOfEX
Is the mod neccessary...
I think that is up to you. I have not done the mod yet but am going to. I leave my truck idling for extended periods in the summertime with my dog in it. In the Georgia summer heat it cools okay at idle but, it would do better if idled up slightly. That's why I am going to do the mod.
Probably any time the truck idles for an extended period, the high idle would give you a higher alternator output, more coolant flow, better A/C and heat function.
While writing this response I just read a few threads about alternator output, voltage, and the effect of low voltage on the FICM. Seems like low voltage will eventually ruin the FICM, an expensive part. I can see that extended idling in summer heat, front and rear A/C fans running, might cause a low voltage condition? Maybe maybe not. To be on the safe side I am going to do the High Idle Mod this winter!
Old Dec 1, 2010 | 06:26 AM
  #41
Jayybird's Avatar
Jayybird
I am also interested in the answer to this question. If anyone has any input, please chime in.
However, from what i've read so far. It appears that this mod is good and should be used regardless if EGR has been blocked/deleted as the high idle keeps your truck's electrical system fully charged keeping all electrical components working properly.
Old Dec 1, 2010 | 07:06 AM
  #42
bismic's Avatar
bismic
The strategy only keeps the idle up for a limited time IIRC. You really need the elevated idle for several reasons. Yes it helps your electrical system somewhat, but it also helps get your engine closer to operating temperature (which is hard to do w/ a diesel engine at idle).
Old Dec 1, 2010 | 07:32 AM
  #43
southbound35west
i have done the high idle mod and upfitter switch install, it is a great mod to install, it is about 25 degrees where i am at right now, i just went out and flipped the high idle on (Aux-4 swicth) , so she will be nice and warm when i get in her in about 5 minutes, also in the summer it works great to keep a/c cold when at idle, i was also told it can prevent wet stacking in the engine by using high idle when setting still for long periods, when i flip my high idle switch i see the rpm's jump to about 1300rpm's, this mod works well when u are trying to jump a dead battery off also, this mod is worth every penny, in my opinion.
Old Dec 1, 2010 | 09:42 AM
  #44
Jayybird's Avatar
Jayybird
Thanks for all the good info, you guys are AWESOME! I really appreciate the help.
I will be doing this to mine!
Old Dec 1, 2010 | 03:38 PM
  #45
SFC-REMF's Avatar
SFC-REMF
Just for info sake, on my 04 per the mod directions in the 6.0 tech folder (great resource) I direct wired wire 322 and wire 294, worked like a charm she went right up to 1200 rpm.
I was going to leave it as just a hard wire but this morning it was –5 degrees, and needless to say the truck was a bit chilly. I have an auto start on the rig so I sit in the house drinking coffee while I fire her up. She started fine and went right to high idle. She did sound a little rough at first but smoothed out in about a minute or so at high idle. After listening to her this morning in the cold I added the toggle switch, very easy.
I just feel I will let her warm up a bit with the auto start, then I’ll walk my lazy a$$ outside and flip the switch. Great mod, thanks to all who contributed to it. HOOAH
