Swagger : Build Thread
Old Oct 21, 2011 | 09:23 PM
  #571
rat49f6's Avatar
rat49f6
shop sound system is set up :
kenwood cd/dvd/mp3 headunit
2 12" kenwood db+ subs powered by
Kenwood mono block 1000 watt class d amp
4 pioneer 5 x 7 3 way speakers
super duty battery staying charged with a small 2/4/6 amp charger
system even has a capacitor
let me tell u its way better than any boom box
Old Oct 21, 2011 | 09:25 PM
  #572
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Does it have an iPhone jack?
Old Oct 21, 2011 | 09:31 PM
  #573
rat49f6's Avatar
rat49f6
yep female usb
Old Oct 21, 2011 | 10:06 PM
  #574
sddesigns's Avatar
sddesigns
FTE Emeritus
Cool, I've got a coolant leak I'll be working on tomorrow, or else I'd swing by.
Old Oct 21, 2011 | 10:13 PM
  #575
fordpride's Avatar
fordpride
Looks good. Whats the plans for the doors?
Old Oct 22, 2011 | 01:25 PM
  #576
dougbrown's Avatar
dougbrown
Originally Posted by sddesigns
Doug, it's actually closer to my house mileage wise, just not highway most of the way.
The old swag shop was about an hour and 40 mintues. Now it just under 3 hours and 130miles one way!
Good luck steve! I hate dealing with coolent!
Old Oct 22, 2011 | 04:25 PM
  #577
rat49f6's Avatar
rat49f6
Doors, are going to be stock ...its an extended cab
Old Oct 26, 2011 | 12:04 AM
  #578
rat49f6's Avatar
rat49f6
got the bed all lined up ... what a PITA that was alone
the passengers side mount is under the bed and tack welded in place
the body lines line up better now than they ever did
tomorrow ill finish the drivers side front one and fully make the rear supports
once the rears are made and tacked into place ill be able to lift the truck and place the drivers side front one
then back down to work on the middle 4
Old Oct 26, 2011 | 01:50 AM
  #579
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Looking good Jim!
Old Oct 26, 2011 | 10:47 AM
  #580
High Intentions's Avatar
High Intentions
Mod Specialist ;)
Nice. Lined up great.
Old Oct 27, 2011 | 10:17 PM
  #581
rat49f6's Avatar
rat49f6
finally got the 4 main bed mounts built
did the front passengers side first by reaching it threw the stack hole in the bed
pic taken under the truck looking tword the cab after tacking in place
measured out the drivers side front but couldnt get under the truck to install it
so on the the back
first i built a cross member under the bed welded that to the bed floor
then the uprights were made and welded onto the frame
pic taken from under the truck looking out the tailgate
the i vice gripped the bed to the cab on the drivers front corner and aired it up
Old Oct 27, 2011 | 10:24 PM
  #582
rat49f6's Avatar
rat49f6
then the front drivers side got tacked into place
some random pics
me sitting where the fuel tank belongs welding the back two uprights in place
looking at the rear axle from the tailgate
high rider
some pics of it laid out
Bumper???
Old Oct 28, 2011 | 02:00 AM
  #583
7.3 Rocket's Avatar
7.3 Rocket
I think yes bumper. Gives it that big truck feel still. Roll pans are for s10s
Old Oct 28, 2011 | 02:03 AM
  #584
BigAlsPSD's Avatar
BigAlsPSD
Looking great Jim, I'm with Pete, I like it with the bumper, but could see some of the issues if you were dragging it, maybe add some tie plates to the lower lip to counter the drag?
Old Oct 28, 2011 | 02:05 AM
  #585
7.3 Rocket's Avatar
7.3 Rocket
Steel bumper will hold up to the dragging better than a fiberglass roll pan as well.
