S. California Chapter Join Chapter, Leader:
November All Topic
Old Nov 7, 2010 | 01:40 AM
  #136
76f350spercamprspeal's Avatar
I know what that is...
I was askin' you what the hell that thing is to the left of it, with all the wires runnin' out of it...
Old Nov 7, 2010 | 01:45 AM
  #137
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Heater blower motor.
Old Nov 7, 2010 | 01:47 AM
  #138
I was thinkin' it was the starter solenoid or somethin'...
Old Nov 7, 2010 | 01:57 AM
  #139
NumberDummy
Starter solenoid? (sigh) What in the world?
You wanna find the solenoid? The positive battery cables (edit: cable) connects to it.
Old Nov 7, 2010 | 01:02 AM
  #140
You wanna find the solenoid? The positive battery cables connects to it.
Don't you mean cable? There is one positive, and one negative...
Old Nov 7, 2010 | 01:37 AM
  #141
NumberDummy
Yes, the added 's' was a typo.
Since all 1956 and later FoMoCo vehicles are 12V negative ground, the negative battery cable is grounded.
So, it has nothing to do with the starter solenoid.
V8: The usual location to ground the negative battery cable is by using one of the exhaust manifold to cylinder head mounting bolts.
Old Nov 7, 2010 | 01:54 AM
  #142
Sparx Macgyver's Avatar
Sparx Macgyver
Just a couple things left. Gotta install the fittings on the trans cooler lines at the rad side. Finish putting the pan/dipstick tube on,and then fire it up and see if it's fixed. Aside from that, just need to swap the tire.
Old Nov 7, 2010 | 01:58 AM
  #143
Sparx Macgyver
Tony, sorry,but for some reason,that cross on your coffee table disturbs me. I don't know why. Anywho, time for some sleep for an early day tomorrow.
Old Nov 7, 2010 | 02:16 AM
  #144
NumberDummy
There is an O-ring on the dipstick tube. If you use the old one (or don't use any), you'll have a leak.
O-rings should not be reused, because they harden up/age crack.
The same O-ring (87034-S94) is used for all 2 & 3 speed F-O-M's, FX, FMX & MX C-O-M's, C3, C4, C5, C6, AOD, so every FoMoCo dealer should have it, and autoparts stores.
Old Nov 7, 2010 | 02:20 AM
  #145
Sparx Macgyver
I got a new one all ready to, but thank you for that tidbit. I decided to get a few bits I figured I might need to replace. There cheap, so what the heck, why not.
Old Nov 7, 2010 | 02:27 AM
  #146
NumberDummy
There are so many crosses, religious icons and santos in the living room, it looks like the gift shop at the San Gabriel Mission.
The only thing missing are the price tags.
Old Nov 7, 2010 | 07:46 AM
  #147
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Not only does that not alway's work, what if the house never had a water closet, then what do ya do...?
Pee in a bucket or go outside.
Old Nov 7, 2010 | 09:41 AM
  #148
SpringerPop's Avatar
SpringerPop
Tony, sorry,but for some reason, that cross on your coffee table....
Was it ever established where the photo of the room was?
Is it a room that the sewing machine WAS in before purchase?
Is it Anthony's living room, where the machine is NOW?
Is it someplace that his dad is putting stucco on the outside of?
Is it the place to which his dad and friend drove the '76?
Is it the gift shop of the San Gabriel mission?
I never got that for sure.
Pop
Old Nov 7, 2010 | 09:56 AM
  #149
bpounds's Avatar
bpounds
So many questions...
I'm not clear on why the Crucifix bothered you, Sparx. Lots of people like a lot of symbolism in their lives.
Old Nov 7, 2010 | 10:45 AM
  #150
SteveBricks
FTE Emeritus
I won a certificate for a shiny new AFE intake at the dyno event yesterday. Didn't take more than about 3 minutes to find someone to give it to.
