icp location
Oct 30, 2010 | 11:57 PM
icp location
I have an 05 crewcab where is the icp located?
Oct 31, 2010 | 12:01 AM
Passenger side valve cover
Oct 31, 2010 | 12:10 AM
Is there a sensor under turbo on this model year?
Oct 31, 2010 | 12:24 AM
No, but the regulator for the oil pressure (high pressure system) is located under the turbo (on the HPOP cover actually) ..... called the IPR.
Oct 31, 2010 | 12:32 AM
Thanks. Is this the sensor you used the modified wrench to remove it with?
Oct 31, 2010 | 12:35 AM
You do not need a modified wrench to remove the 05 ICP sensor.
Oct 31, 2010 | 09:05 AM
ICPv
Here is a pic of the location of your ICP. It's in lower section of picture.
Nov 3, 2010 | 10:40 AM
if have have a no start and pull this plug and the truck starts, the sensor is bad?
Nov 3, 2010 | 08:46 PM
where is the icp sensor on a 03 6.0?
Nov 3, 2010 | 09:40 PM
Here is where it is. Tough area.
Nov 4, 2010 | 10:53 AM
Quote:
Originally Posted by
o3stroker
Drivers side under the turbo
patino1
Mar 1, 2025 07:41 PM
cruzer17
Jul 6, 2017 06:20 PM
mudrat025
Jun 21, 2016 09:51 PM
bebeard
May 12, 2012 10:01 PM
morson82
Jan 7, 2011 07:57 PM
03 ,
05 ,
60 ,
f250 ,
f350 ,
ford ,
high ,
icp ,
located ,
location ,
oil ,
pics ,
preasure ,
problems ,
sensor
