vin decoding
Old Dec 27, 2010 | 08:10 PM
morson82's Avatar
morson82
vin decoding
I need a new icp for my 1997 f350 7.3... The parts guys wanted to know what the engine serial number was because there are 2 different sensors for different building serial numbers...
I tried to check behind the block but could not locate anything...is there a way to decode the vin to find out which series motor is in the truck? I checked the old icp and could not locate a number on it....
Any suggestions......
Old Dec 27, 2010 | 08:21 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Here is the serial number and a link for the VIN decoder:
VIN Number Decoder offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
Old Dec 27, 2010 | 08:23 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
And here some numbers for you
ICP Sensor
(Ford) F4TZ-9F838-A (94/95)
(International) 1830667C91 (engine S/N 375548 and prior)
(Ford) F6TZ-9F838-A (96-up; marked Julian date 6318 or higher)
(International) 1807329C91 (engine S/N 375549 and after)
Old Dec 27, 2010 | 08:37 PM
morson82's Avatar
morson82
where exactly can I locate my engines serial number
Old Dec 27, 2010 | 09:46 PM
Ken_C's Avatar
Ken_C
the picture above that has 2 fingers in it. that is the High Pressure Oil Pump Reservoir right on the front of the engine the serial number is on the lowest sticker whith the barcode. (right?)
and where is it stamped into the block? i cant tell where that is but I can make out the serial number (circled in yellow with the arrow)
Old Dec 28, 2010 | 10:29 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
You can see in the pic partially part of the OIL COOLER, I hope this helps you..
Old Jan 7, 2011 | 07:57 PM
DPorter's Avatar
DPorter
it decodes as a 97 250 crew 4x4
northerndave
Mar 24, 2017 04:40 PM
Pacecar1986
Jan 2, 2017 05:56 PM
Opus 97
Jun 1, 2016 05:06 PM
Pacecar1986
Jul 17, 2014 08:18 PM
dclarkson
1983 - 2012 Ranger & B-Series
Dec 24, 2011 08:20 PM
