Manual gearbox work on 1974
The 74 F250 farm truck is apart for an engine change-over.
While out of the truck is it a hard repair to install new sinchroes, and other worn parts it may need, to solve my grinding as it goes into second gear.
Yes I have a garage and tools, but limited nowledge of gearbox repair.
As far as transmissions go these are easy to work on. You need a manual that shows the proper tear down procedure. I helps to take some pictures as you go.
Be sure to use new seals and check the end play in the front shaft that goes into the clutch. Most have plastic tips on the ends of the shift forks that can be worn or broken.
You can buy rebuild kits from Jeffs Bronco graveyard.
If you have gears bad, they can get pretty expensive.
Voodoo ChildVood
11-26-2009 06:54 PM
iontkendall
11-04-2007 03:17 PM
