power steeing gearbox
Old Nov 23, 2009 | 08:15 PM
Voodoo ChildVood's Avatar
Voodoo ChildVood
Can anyone tell me if the Bendix power steering gearbox is shorter than the Ford brand gearbox on a 1968 Ford F100. Or are there different length steering shafts for this truck. I am having trouble putting in a power steering unit for my truck. Thanks!!!
Old Nov 23, 2009 | 09:31 PM
steve340's Avatar
steve340
I also have a 69 F100 with the Bendix steering box. I bought a rebuilt one 2 years ago and it is leaking again. It is cheaper to use the Ford box (half the price) but the steering column has to be changed.
Old Nov 23, 2009 | 11:53 PM
jhooch's Avatar
jhooch
The Bendix box is slightly shorter than the Ford unit. The steering shafts are different. I put a Bendix box in my '66 using a steering shaft from a '68 F100 with factory Bendix box. Hope this helps.
Old Nov 24, 2009 | 04:37 AM
jowilker's Avatar
jowilker
VooDoo, If memory serves, the Bendix and non power should swap. It is a the later Saginaw power gear that has to have the column swapped in also.
John
Old Nov 24, 2009 | 07:13 AM
Voodoo ChildVood
I'll visit my local junkyard today and get the right steering shaft. Thanks guys for all your help, very much appreiciated!!!!
Old Nov 24, 2009 | 11:39 AM
jhooch's Avatar
jhooch
John
The Bendix box also requires a different (shorter) shaft when converting from the manual box.
Old Nov 25, 2009 | 09:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6TZ3524M .. Steering Shaft / Use w/Bendix P/S / 34 15/16" long / Flange has (1) 1/2" slot & (1) 3/4" slot / Obsolete
Fits: 1966 F100/250 2WD from serial number 900,001.
Fits: 1967/68 F100/250 2WD.
C9TZ3524B .. Steering Shaft / Use w/Bendix P/S / 34 15/16" long / Flange has (2) 3/4" slots / Obsolete
Fits: 1969 F100/250 2WD before serial number D96,001.
Note #1: 1969 F100/250 2WD & F350 from serial number D96,001 / 1970/72 F100/250 2WD & F350: Ford P/S.
C5TZ3524H .. Steering Shaft / 35 5/8" long / Use with Manual Steering / Flange has (1) 1/2" slot & (1) 3/4" slot / Obsolete
Fits: 1965/66 F100/250 2WD / 1967/68 F100/F250 2WD & F350.
C9TZ3524A .. Steering Shaft / Use with Manual Steering / 35 5/8" long / Flange has (2) 3/4" slots / Obsolete
Fits: 1969/72 F100/250 2WD & F350.
Note #2: F350's were not available w/P/S until mid-year 1969. All used Ford P/S.
Old Nov 25, 2009 | 06:45 PM
Voodoo ChildVood
Power Steering Gearbox
No luck at the junkyard. Here is the problem I am having. I have a 1971 Ford F100 with manual steering. I am trying to convert it over to power steering. Will a 1968 power steering column work on my truck? The steering shaft seems to be a little bit long. The power steering gearbox is a Saginaw and right for the 1971's. I am not sure if the 1968 column came out of a truck with the Bendix gearbox which might explain it being to long. Can I switch just the 1968 shaft with a 1971 shaft? Your help would be appreciated!!!
Thanks
Voodoo
Old Nov 25, 2009 | 08:04 PM
Ford_Six's Avatar
Ford_Six
Here's the article with all the info you need. Modding the existing column is very easy.
Power Steering & Disk Brakes 2wd 65-72 .: Articles
Old Nov 26, 2009 | 06:54 PM
jhooch's Avatar
jhooch
Your 68 column was most likely behind a Bendix box because I don't believe the Ford box was available until '69. Just find a column from a 70-72 with power steering and you should be fine.
sonny1965
WTB - Parts & other
Nov 28, 2016 03:13 PM
rwrogers
Ford Truck Parts for Sale
Jun 18, 2015 12:59 PM
1968 F250camper
Sep 10, 2010 03:00 PM
mapolo
Nov 13, 2009 09:50 AM
mkoser
Nov 5, 2009 06:18 AM
