Sounds like the Transmission Range Sensor. I had a similar problem with my 99 had to jiggle the gear shifter around to get it to start. Then it just wouldnt start at all. I replaced the Trans. Range Sensor, not a bad job just spray the hell out of it and let it sit for a day or so. 15mm center nut and 2-8mm bolts mounting it on the trans. 4R70W But in my case it didnt solve the problem. Still wont start. I think I have something else going on. Going to check the ignition switch next.
