Static Shock
Old Feb 25, 2003 | 12:27 PM
couleeman's Avatar
couleeman
Static Shock
I am getting a static shock every time I get out of my wifes car. Not a little one either, my damn arm went numb for about 5 minutes last time. It doesn't seem to matter whether it goes on a short trip or a long trip. Every time I get shocked.
Is there anything I can do about this????
Old Feb 25, 2003 | 12:31 PM
Mil1ion's Avatar
Mil1ion
Static Shock
Attach a static strap to the frame under the car.
This is a piece of rubber strap that just touches the pavement when you drive.
Old Feb 25, 2003 | 12:34 PM
Bob Ayers's Avatar
Bob Ayers
Static Shock
the strap has to be conductive.......
Old Feb 25, 2003 | 02:22 PM
tw's Avatar
tw
Static Shock
It could be static from your pants to the seat when you slide out. My new seat in my 72 did that. Spray of that static guard on the seat and see if it works.
Tony Warren
Nebraska
Old Nov 24, 2005 | 07:33 AM
PA24180's Avatar
PA24180
Vehicle Static Shock
I too have been anoid by the sharp spark when getting out of my new F150 SCREW. This is the worst of any vehicle I have ever had. I have had 72 chev, 99 Dakota, 99 Ranger, 01 Ram, Jeep, Volvo V70, etc. The DOdge Ram was the first vehicle I have ever noticed his problem with. Zap .. ouch. Sold the vehicle last month (no more pain) and got a 2006 F150 w/no bed liner, and double zap. And it is getting worse as the winter approaches. Now that I have read the articles on fueling, I am more concerned than in pain. I worked at Ford R&D in 1978-1981 and I recall several events with plastic tanks sparking on test stands and techs getting burned. Surely all of our fine engineers have a fix for this painful and dangerous phenomeon. Do the ugly straps really work? Why are some vehicles more prone to his than others (Ford F150 and Dodge RAM)? Should truck manufacturers put an anti-static plate on the dash? I thouht I left my troubles behind when I got rid of the Dodge, but the Ford is worse.
Old Nov 24, 2005 | 07:40 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
This thread is a bit old, however, stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 24, 2005 | 09:02 PM
Franklin2's Avatar
Franklin2
Most of the time it's you who are charged, and you are being discharged through the truck when you touch it. Try to find something metal to hang onto before you slide across the seat, and see if it goes away.
Old Nov 25, 2005 | 01:47 AM
Bdox's Avatar
Bdox
There are a lot of factors. You will notice that it is much worse when the humidity is very low. The material of the upholstery, the material of your clothes too. Here at Tahoe it is a constant problem. I just discharge myself as I get out of the vehicle by putting the heel of my hand on the metal part of the door as I put my foot down on the pavement. It's such a habit now I don't even think about it.
I remember as a kid seeing heavy trucks with bits of chain dragging on the ground. I'm not sure it was for static but it sure made a lot of sparks.
jet2fan
Electrical Systems/Wiring
Nov 26, 2006 09:08 AM
4wdriver
2004 - 2008 F150
Apr 24, 2006 06:13 AM
Tadashi
May 21, 2004 08:35 PM
parks911
19
Apr 10, 2004 11:29 AM
robthai92
1983 - 2012 Ranger & B-Series
Jan 26, 2004 08:11 AM
