static electricity
Old Apr 22, 2006 | 05:13 PM
4wdriver's Avatar
4wdriver
static electricity
not sure why, but I get shocked almost every time I get out of my 05 sc.anyone else get this?
Old Apr 22, 2006 | 05:18 PM
wildcard30's Avatar
wildcard30
Low humidity....
Low humidity allows for the build up of static electricity, either in you or the truck.
You touch the truck, it discharges. Depending who or what has the charge, depends on which way the electricity flows....
Either way, you get shocked...
Old Apr 22, 2006 | 05:58 PM
4wdriver's Avatar
4wdriver
do you think there is anything i can do to stop or minimize this problem.never had this much static in any other truck
Old Apr 22, 2006 | 06:52 PM
cullenkyla's Avatar
cullenkyla
Wal-Mart { static guard } aerosol spray.
Old Apr 22, 2006 | 07:53 PM
wildcard30's Avatar
wildcard30
Or move to a climate with more humidity....
Old Apr 22, 2006 | 10:35 PM
spiggy769's Avatar
spiggy769
I have seen Vehicle Anti Static straps and devices around in auto parts places. There was a post in these forums about them a few months back...maybe if you do a search you can find it. However in the meantime if you can get used to doing it...Just grab and hold your key by the metal part and tap it against the door Frame (Metal Part) when you get out of your vehicle...
Old Apr 23, 2006 | 06:56 AM
charlesh's Avatar
charlesh
Siggy769 has the right idea. You might hold a metal part of the door as you exit to discharge before the build up. I have found that what I am wearing makes a difference. If I have on a certain jacket with a felt liner I could power a light bulb with the static electricity. Much less static in the summer (humid months) but still on occasion a static discharge.
The good news is the static is created from the nylon fibers in the cloth/nylon seats. And nylon wears well, so the seats will last a long time.
Chip
Old Apr 23, 2006 | 07:02 AM
LindenBruce's Avatar
LindenBruce
I have the same problem with the cloth seats on my 06 F-250 cc. I take a hold of the door frame before I slide out and don't get zapped. I usually wear jeans and a cotton shirt. LindenBruce
Old Apr 23, 2006 | 07:05 AM
4wdriver's Avatar
4wdriver
Great charlesh my wife says ill be drivin this truck till its fallin apart around itself.maybe the static guard will work.
Old Apr 23, 2006 | 07:31 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
In NM we have been averaging 11% humidity it is real bad.
Old Apr 23, 2006 | 04:15 PM
hllon4whls's Avatar
hllon4whls
This is what works for me as well. I grab the door frame before I get out and it dissapates the static before I get zapped.
Old Apr 23, 2006 | 09:10 PM
the4by4freek's Avatar
the4by4freek
Or you could just put leather in it! HAHAHA!
Old Apr 24, 2006 | 02:55 AM
HankMurphy's Avatar
HankMurphy
Exclamation Don't Use Your Truck Key To Ground Out Static!
Bad idea IMHO. There are two reasons why I would not recommend this on a truck.
First, the expensive key with the RFID tag. I have no idea if a static electricity spark will travel to, and fry the RFID electronics...but I don't want to find out. This is not a bad idea - I used to do it with doors leaving the office - but use another key.
Second, if you have a real good charge, you can see a visible spark as the key nears the metal ground used for discharge. This is fun to watch, if you don't mind the little pulse of electrical energy going through your finger, and the occasional gas station explosion when you emit an open spark in the presence of gasoline fumes.
So...it's not a bad idea in a couple of other situations...but I would not do it in my truck.
Cheers,
Hank Murphy
2005 XL Work Truck
Old Apr 24, 2006 | 03:59 AM
Torque1st's Avatar
Torque1st
Posting Legend
My wife has a -cough- Buick and it about fries me when I get out of it and touch the edge of the door to close it. Just try to find a metal part in a GM to ground yourself against while getting out...
Kansas City is usually humidity central but it has been dry here for months.
Old Apr 24, 2006 | 06:13 AM
todd31277's Avatar
todd31277
use your knuckle and touch the paint in the door jam. just enough to discharge with driving ya nuts
waystro
Apr 10, 2013 11:43 PM
jhooch
19
Jul 6, 2011 09:31 PM
ford2go
User Gallery & Picture Display
Jun 24, 2008 06:24 PM
electricmaniac2
Offroad & 4x4
Nov 19, 2002 07:13 PM
billyb
May 12, 2001 10:56 PM
