How can I.......
Old Apr 9, 2004 | 10:35 PM
parks911's Avatar
parks911
How can I.......
Reduce Static Electricity In My Apartment?
I have a nasty static build up in my apartment. every time I walk & touch something I get a shock of a lifetime, Including my computer & walls.
It does this when I have shoes on & off.
Old Apr 9, 2004 | 10:38 PM
ChevySniper's Avatar
ChevySniper
wear rubber boots...maybe..
surprise people with a nice shock to the back of the neck...gotta love those.
Mil1ion's Avatar
Mil1ion
Just Buy a Humidfier <>
or
Dance around the house spraying *Cling Free* in the Air.
Old Apr 9, 2004 | 10:47 PM
Phat02's Avatar
Phat02
We use a spray from ZEP called X-290 at work. The floor is carpet and the panels are steel, so static can get really bad. This spray works very well, and does not stain the carpet.
wlihntr's Avatar
wlihntr
yep get a humidfier...
Old Apr 9, 2004 | 10:50 PM
King Triton's Avatar
King Triton
Another inexpensive way is,if you have floor registers,put a bowl of water on a few of them,it will help put humidity in the air.
Old Apr 9, 2004 | 11:33 PM
parks911's Avatar
parks911
Humidifiers will work then. I may have to spring the few buck & buy one.
KT,
Unforutunatly I don't have floor registers. I got those darn ole wall heaters from a boiler, can't remember the technical term for them.
Old Apr 9, 2004 | 11:35 PM
Mil1ion's Avatar
Mil1ion
Radiators ?
THe Steam or Hot Water style ?
Old Apr 9, 2004 | 11:39 PM
parks911's Avatar
parks911
Originally Posted by Mil1ion
Radiators ?
Hot Water.
Their are 16 Apartments in this building & the old gezer of a care taker runs those boilers full blast because he is cold. It is 50 degrees outside & I have all my windows open & patio door open just to remain comfortable.
I sure wish I had control of my own heat.
Old Apr 9, 2004 | 11:40 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Not much humidity in Pequot Lakes, MN. You would think that MN would have plenty of moisture, If you can find some it will help.
Old Apr 9, 2004 | 11:43 PM
parks911's Avatar
parks911
Tim your correct.
There isn't much for humidity up here. I think it might have something to do with those boilers.
Old Apr 10, 2004 | 12:13 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Humidifier. Low cost solutions are putting a pan of water on your stove and leave it on real low or you can plug in one of those vaporizers from time to time (add a timer maybe).
Old Apr 10, 2004 | 06:26 AM
IB Tim's Avatar
IB Tim
Originally Posted by parks911
Tim your correct.
Just out of curiosity, what is the average humidity up there.
Here in NM it is 20% we can see at times of hard rain 80% and it drops within hours to 32, then one to normal.
Old Apr 10, 2004 | 07:03 AM
christaylor's Avatar
christaylor
Maryland has a lot of humidity and it sucks in the summer.
Chris
Old Apr 10, 2004 | 08:36 AM
Loyd Lucas's Avatar
Loyd Lucas
Sears probably has a nice six gallon belt type humidifier for about $100.00. It will last for years.
