IPR questions
Old Oct 16, 2010 | 02:04 PM
79_250RangerLariat's Avatar
79_250RangerLariat
IPR questions
My IPR is leaking oil pretty good, it's even in the plug. Is it still rebuildable or is it ready for replacement? Next question is if it's rebuildable how does it come apart? I took the tin nut and sleeve off but nothing else would come out..
Tried taking the IPR out as a assy but it won't spin past the plug, does the HPOP need to come out?
Old Oct 16, 2010 | 02:22 PM
strokin'_tatsch's Avatar
strokin'_tatsch
You need to take the tin nut off, pull the solenoid off, then use a DEEP 1 1/8" socket on a 1/2" drive ratchet to get it out. There is are 3 o-rings on it, change them all w/ the kit from Ford. The big one at the base of the threads can leak some.
Old Oct 16, 2010 | 03:03 PM
cowmilker08's Avatar
cowmilker08
You can get the kit for cheaper from IH. Also I can send you the tool I used to change mine. I owe you one, lol.
Old Oct 16, 2010 | 04:52 PM
pjwoolw's Avatar
pjwoolw
Or get the kit from dieselorings.com. A site sponsor.
Old Oct 16, 2010 | 06:02 PM
79_250RangerLariat
Thanks for the response guys! Dummy me wasn't getting the selonid free of the shaft. Was able to get a 1 1/8 closed end wrench and break it free. (thanks for the offer Phil!) The rings looked ok, but will wait till the IH dealer opens up monday.
Pulled and IPR off an old bus engine but the last ring on it was busted.
bigpimpin
Nov 29, 2013 10:12 PM
LSO1123
Mar 25, 2013 06:54 AM
LSO1123
Mar 20, 2013 10:58 PM
cowmilker08
Dec 21, 2009 05:44 PM
haulingboat
Feb 18, 2008 08:18 AM
