Reset Speedometer
Old Mar 10, 2003 | 07:26 PM
big_saxy's Avatar
big_saxy
Reset Speedometer
I have a e4od,, not an AOD,, does an E4OD have a TV cable?
Old Mar 10, 2003 | 07:53 PM
big_saxy's Avatar
big_saxy
Reset Speedometer
I guess the e4od does not have a tv cable.. but if the psom is bad will it cause speedo to jump and overdrive to not engage? I also have this funny simptom when I come to a stop, It feels like the tranny is sticking either in third or forth when I go to take off again, Somtimes feels like it thinks its N. I just tap the gas a tap the gas and let off and it feels like it kicks down,, because I have been doing this and it feels like the tranny isnt making any power my gas mileage is sub 8 mpg or so! And I do say it is getting worse. even after complete tune up, map, o2, egr, tps, IAC, air, and coolent sensors! Im sure this is a common problem, Im just blasted I cant get it!
Old Mar 10, 2003 | 10:34 PM
steve83's Avatar
steve83
Reset Speedometer
E4OD has no mechanical control other than the shift lever. TV cable is for AOD only.
You could have serious internal mechanical problems - a friend of mine had similiar symptoms from a Jasper reman E4OD and it turned out some internal bolts were vibrating loose. He swapped to an M5OD.
Old Mar 11, 2003 | 02:19 AM
big_saxy's Avatar
big_saxy
Reset Speedometer
How much did all that set him back? I dont think my tranny is all bad though, it screws up intermitantly?
Old Mar 11, 2003 | 07:02 AM
steve83's Avatar
steve83
Reset Speedometer
You'd have to contact him, but his started off like that.
TheKirbyMan
39
Sep 1, 2019 04:12 PM
1968bumpside
Mar 16, 2012 12:36 PM
shotgun
21
Oct 25, 2010 09:56 AM
SPL Tech
Apr 2, 2007 05:11 AM
Als03FX4
Feb 16, 2007 06:15 PM
