Excursion speedometer 4 MPH off @ 75 MPH?
Old Mar 13, 2007 | 01:05 AM
SPL Tech's Avatar
SPL Tech
I am wondering if anyone noticed the speedometer on the Excursions is off? Because it appears mine is. At about 75 MPH my speedometer reads about 4 MPH fast. I know it reads fast because when the Speedometer says 80 MPH my GPS says 76 MPH. Well I don’t think the GPS is off because the speed display on the GPS matches up within 1 MPH to the speedometer on both my Jeep and my Toyota. I have stock tire size. Is there any way to adjust the speedometer? It does not appear to be constantly 4 MPH off. As I drive faster the speedometer reads increasingly faster then the GPS.
Old Mar 13, 2007 | 02:28 AM
1's Avatar
Even though they are rated as stock size tires, their rolling diameter may be different. Ive seen this especially in the tires built for sports cars. I have the same size tires on my camaro front and back. 275/50/17 but the goodyear eagl F1GSD3's are probably close to an inch taller then the same zied pirelli P-Zero Nero M+S On the front.
Go to your tire manufacturers website and you should be able to find the tires rolling diamater (i beleive thats the term? its how many inches it travels in exactly 1 rotation) and compare it to your stock tires rating. You may be surprised at the difference.
Old Mar 13, 2007 | 02:37 AM
Fleetsuper's Avatar
Fleetsuper
Mine is consistantly off 2 mph from about 30 mph to 50 to 55 mph and then gets higher, in your range 3 to 4 mph off over 60. I've checked mine with other vehicles and with those radar detector trailers the cops set on the side of the road to tell you your speed and get you to slow down. I also have stock tires.
It's not uncommon to have your speedo be a little off. Even certified poice car speedos can be off, they are just certified that they read x mph.
Old Mar 13, 2007 | 08:06 AM
Matt M, PA's Avatar
Matt M, PA
Mine is a couple off as well....reading higher than it should.
I installed a Scan Gauge and found that (after setting the SG up with my GPS) the truck's computer knows the right numbers, it's the dash speedo and odometer that are off.
I asked my tech about it, and frankly have been too busy to get back with him. He also said that the only speedos that are certified accurate are for Police cars. Interestly, he said that a speedo is like any other gauge that will be more accurate in certain parts of it's swing that others. So, while it may be more accurate in one speed zone....it can be worse than others.
Some say that there is a correction that can be made in the software.
A friend has an '05 SD that also reads high.
Old Mar 13, 2007 | 08:59 AM
EpicCowlick's Avatar
EpicCowlick
Everyone's speedo is likely to be off at some point in time. The diameter changes as the tire wears and can make a difference as much as 3% over the life of the tire. I just calculate my actual speed occasionally by using the mile markers on the side of the road. Set your speed to exactly 60 mph and mark the exact start time as you cross one mile marker and the exact stop time as you cross the mile marker at least three miles down the road. Remember high school math? Distance divided by time = speed. The actual formula is 3miles/180secondsX100X100. 60 Mph. When you know what your speed is vs. what the speedo is saying, you know that for today, your speedo is off by x% in all speed ranges. Piece of cake.
Old Mar 13, 2007 | 11:36 AM
njstevens's Avatar
njstevens
It seems everyone has hitmost of the reasons why speedo's are off. Tires are the biggest culprit always. I never even worry about it becuase I can never see what my speedo says since the top portion of my steering wheel is alwasy in the way. The only down flaw I do not like about my X, but then again that is because of my own driving preference.
Old Mar 13, 2007 | 01:42 PM
bigdog55's Avatar
bigdog55
If your speedo is off,does that mean that your odometer is off too??? It seems to me that I remember a report not too long ago, on television (if it's to be believed) that several manufacturers were setting them so that the warranties ran out sooner..I don't think that I could really believe that,BUT it could be..If your speedo is four miles faster at speed,then how much sooner will you get to warranty mileage????
Old Mar 13, 2007 | 01:52 PM
Matt M, PA's Avatar
Matt M, PA
bigdog...YES...your odometer would indeed read higher than it "really" is if the speedo is reading high. I figured mine to be 1 mile for every 100 or so.
Old Mar 13, 2007 | 02:01 PM
MarkMoore's Avatar
MarkMoore
Did you hear about the lawsuit against Honda because the speedos racked up more miles, faster.
Anyhow - the ASE Standards allow a variance of +/- 4%, but that is "Voluntary".
Old Mar 13, 2007 | 11:40 PM
SPL Tech's Avatar
SPL Tech
Well anyway I dont care what the problem is. I just care about how to fix it. So how do I adjust the spedo?
Old Mar 14, 2007 | 02:57 PM
3KIDDAD's Avatar
3KIDDAD
My understanding is that there is no adjustment it's a fixed setting in the computer and that the only way to change it is a device by Superlift called TruSpeed, about $200 it installs inline with the speed sensor and modifies the signal sent to the computer.
Old Mar 15, 2007 | 01:45 PM
weekendwander's Avatar
weekendwander
Just a thought. I have access to a few different GPS systems. One of them is dead on with my spedo. The other one is about 2 MPH different than my spedo. This is the same on 2 different vehicles so it is making me believe the GPS is slightly off in the speed calculation.
Old Mar 15, 2007 | 02:35 PM
SPL Tech's Avatar
SPL Tech
I doubt it. The GPS says the exact same speed as both my Jeep and Toyota.
Old Mar 15, 2007 | 06:47 PM
sewerat's Avatar
sewerat
Hey SPL when did you go thru Installers Insitute? I was there in 95
Old Mar 15, 2007 | 07:51 PM
dougger222's Avatar
dougger222
All three of my Ford's speedo's are off. They all have larger than stock tires and all go faster than what the speedo reads. Tested them all with two different GPS's and the Microsoft navigation.
If your speedo says your going faster than you are you may be able to fix it by getting taller tires.
