- Ranger 4.0 Poor Gas Milage
- 4.0 Doing crazy weird things
- rockers rolling
- breath deeply
- 4.0L SOHC Plug & Wire Change?
- 01 SOHC 4.0 cold poor idle, no code, good IAC
- 2.9 push rods keep popping loose!
- Will I have to prime oil pump becasue I did this?
- OMG not another problem with ticking
- Vacume Tubes
- TBI sharpning
- '01 Ranger Stalls when almost stopped
- I need Help 2.9 timing chain check and replacment
- swapping to a 58mm TB
- Cork or rubber?
- rebuilding 87 2.9 liter
- Contemplating a 1987 Ranger w/ 2.9 V6
- How do I remove the Fan of a 4.0 OHV
- 93 Explorer 4.0
- Problems 93 4.OL
- '94 4.0 Timing Cover leak
- idle issue
- 4.0 Ohv quality info wanted
- '00 4.0L misses at idle in gear
- 90 ranger oil pressure and tap
- Ranger EGR low voltage
- 4.0L SOHC Engine Noise - Weird
- 84 2.8L duraspark conversion
- Cold air intake question
- Polishing MAF/TB Body
