1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
high oil temp on 6.0
Old 07-17-2010, 08:09 AM
solomon99's Avatar
solomon99
solomon99 is offline
what will cause high engine oil temp in the 6.0
Old 07-17-2010, 08:18 AM
rickf92592's Avatar
rickf92592
rickf92592 is offline
Oil cooler fail?
Sorry, not pretty.
Old 07-17-2010, 08:39 AM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Welcome to FTE
How high is the oil temp? Do you know the temp difference between the coolant and the oil? If it constantly exceeds 15 degrees your oil cooler is bad, as Rick said.
Old 07-17-2010, 09:13 AM
solomon99's Avatar
solomon99
thanks i its running about 250
Old 07-17-2010, 09:34 AM
SteveBricks
What's the coolant temp running?
Old 07-17-2010, 11:22 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
Coolant wouldn't stay in the system at 250, it would be blowing steam, so sounds like the oil cooler is plugged up.
Old 07-17-2010, 01:41 PM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf is offline
Yeah, 250 sounds high to me. +1 on the oil cooler.
Old 07-17-2010, 09:24 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Powerstroke_wannabe is offline
You're on borrowed time with the oil cooler. I'd get it replaced ASAP.
Old 07-18-2010, 02:25 AM
flamebuster's Avatar
flamebuster
flamebuster is offline
250 is way to high, most likely burnt the oil by now.. replace the oil cooler asap as said and change the oil and coolant. Along with a vc.9 flush.
Old 07-18-2010, 10:04 PM
rickf92592's Avatar
rickf92592
While I agree that he needs to zero in on the cooler, intermittant 250 deg oil isn't the end of the world, especially for synthetics.
Also, it is important where the sensor is for the oil, post-cooler or pre-cooler. Your engine sees 250 deg oil more than you'd like to know with a turbo.
Old 07-18-2010, 10:13 PM
UrbanXX's Avatar
UrbanXX
UrbanXX is offline
Make sure you oil pressure gauge is operating as it should before spending a lot of loot.
Old 07-19-2010, 12:18 AM
flamebuster
True; I was taking it as running steady at 250. ....
Alex Rodriguez
05-11-2017 01:47 AM
m4ff3w
07-05-2016 10:16 PM
mgood
02-28-2012 05:28 PM
Superduty21
11-21-2011 04:08 PM
jeeplj8
07-11-2011 08:54 PM
Quick Reply: high oil temp on 6.0
