6.0 temp questions
Old Nov 21, 2011 | 09:06 AM
Superduty21's Avatar
Superduty21
6.0 temp questions
i was pulling a empty trailer yesterday on the highway for about an hour at 65 mph and my eot climbed up 235 and stayed there. the eot has never gotten that high before. the tranny temp got to 163 when the oil temp climbed. the coolant temp didnt climb above 188. are these normal numbers or should i be concerned? what should the temps be normally at? what do i need to do to bring the temps down?
Old Nov 21, 2011 | 09:44 AM
BLADE35's Avatar
BLADE35
well the spread should be taken eMPTY but with a 47* spread Id have to say time for a new oil cooler
what year is your truck if an 05+ be careful those square cooler suck
Old Nov 21, 2011 | 09:46 AM
Superduty21
Its an 04. Should I replace with a stock cooler or do an aftermarket one?
Old Nov 21, 2011 | 09:57 AM
BLADE35's Avatar
BLADE35
I would flush its guts out put a coolant filter on it and go back OEM that bullet proof is cool but once the system is cleaned out you shouldnt really have to worrey but it must be flushed clean with the cooolant filter to catch anything eles
that Bullet proof is nice but not 1800.00nice IMO
sosme just go with it cuz theres no more worries at that point
with OEM you Always have to worrey aBout a rupture oil cooler and you cant always see that coming
Old Nov 21, 2011 | 10:13 AM
Striderwv's Avatar
Striderwv
Here are the recommended readings.
Recommended readings - Temperature and Pressure - Ford Truck Enthusiasts Forums
Your eot is getting too high, but yur ect seems a little odd. How old is yur thermostat and coolant? If it is old I would start with a new thermostat and flush, it may help cool things down. Here's a thread that may help.
VC-9 Before and after; Worth the money - Ford Truck Enthusiasts Forums
There are special coolant test strips that are needed to test wether or not you need the VC-9.
Blade 35 is probably right about a new cooler, but I would try the new thermostat and flush first. You will need to flush it out before an oil cooler R&R anyway. If you live in a warmer climate or have a heated garage you can just run the distilled water to see if things improve.
You may want to update yur signature, this helps everyone figure things out. Put as much info that you can.
Old Nov 21, 2011 | 12:55 PM
Superduty21
The coolant was just replaced when the radiator was replaced. Ill replace the tstat and do a coolant flush. Ill also have to install the coolant filter. Is there a kit that's available or is it something that's made?
Old Nov 21, 2011 | 02:31 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Many companies making kits. Most between $100-150 and use the same filter. NAPA has the filter housing and you can plumb it yourself if you want to save a few bucks. I
Liked the kit from Sinister (MKM) cool blue filter housing, high silicone hoses with the T's swedged on. Installs in a half hour. I have some pics in my gallery if you want to see the install
Old Nov 21, 2011 | 04:08 PM
Superduty21
Thanks. Ill check them out
JamesMcMn
Oct 17, 2016 10:47 PM
mdmbike
Jan 6, 2016 07:37 AM
Excurvelle
Oct 19, 2014 08:36 PM
jflo631
Oct 23, 2011 11:27 PM
fomoco60
Apr 6, 2011 07:40 PM
