1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
High Temps with A/C on 2005 F250 6.0
Old 05-01-2017, 04:46 PM
Alex Rodriguez's Avatar
Alex Rodriguez
Alex Rodriguez is offline
Hey guys been battling this high temp issue for a bit now. Here's the recap on my truck.
2005 F250 6.0
120k miles
Edge insight CTS2
New factory Oil cooler
motorcraft coolant -system flushed
Stock EGR- No leakage
Deltas 3-5 degree apart no A/C on
A/C works great!
-Issue-
when I turn the A/C on city on normal driving no loads or towing.
the temps have gone up as high as 230 eot 230 ect.
ambient temps 83-90F
Has anyone had similar issues or what can the issue be?
thank you for your time
Alex
Old 05-01-2017, 04:59 PM
kcducttaper's Avatar
kcducttaper
kcducttaper is online now
I'd start by just cleaning out your radiator as best you can of debris and giving your cooling system a good flush. Not just a drain-and-fill, but drop some coolant flush in there, run it for a while, then flush it all out good with water until it runs clear and refill with the appropriate mixture of antifreeze.
Your a/c compressor is in front of your radiator, so when your a/c is on, you're getting pre-heated air over your radiator. If your radiator is plugged with a bird nest, or getting a layer of grime built up on the inside, it won't be able to cool as effectively as if everything were clean in there, or if it were getting non-preheated air.
Old 05-01-2017, 05:18 PM
DarkStarMedia's Avatar
DarkStarMedia
DarkStarMedia is offline
Do you hear the fan when it gets hot? could be a bad fan clutch.
Richard
Old 05-11-2017, 01:47 AM
Alex Rodriguez
Update on to what I have done so far.
Good news temps are actually lower than before.
temps in 80F - Deltas have been between 3-5 degrees
201 eot
198 ect
at night 60-65F
192 eot
186 ect
-full flush with VC9 -back washed as well with both engine plugs open.
- new aluminum radiator
-CAT Elc coolant 3gallon concentrate toped with distilled
Highest reading was 208 in traffic on a grade.
Bad- I have not heard the electric fan come on. That distinct roar has not come at all. So seems like that should be the last culprit in this issue and I am back to normal.
jakoolin
70
10-25-2021 02:14 PM
FiveOJester
12-01-2015 01:36 PM
rustED_
15
07-25-2015 01:23 PM
LSO1123
07-07-2015 11:49 AM
Santa Vern
2004 - 2008 F150
07-30-2014 08:26 PM
Quick Reply: High Temps with A/C on 2005 F250 6.0
